[Qgis-user] Rasterize (vector to raster) no longer exists
Etienne Tourigny
etourigny.dev at gmail.com
Wed Jul 17 19:00:53 PDT 2013
On Wed, Jul 17, 2013 at 9:15 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> I found the git commit (hopefully just the one). Applied and seems to
> work.
this one?
https://github.com/qgis/Quantum-GIS/commit/0c0f0883ed99bb622bbc7b1aa505b814c4152756
I am not sure it is sufficient, there was a note there about the widgets
needing fixing too. Without those fixes some options will not be available.
Not sure which subsequent commits are needed...
> I can package an update later...
> On Jul 17, 2013, at 6:54 PM, William Kyngesburye wrote:
> > If it's GDAL 1.10 causing the problem, did anyone say anything on the
> list or in a bug report. I just blindly rebuilt my OS X QGIS to use GDAL
> 1.10, it would have been nice to know I should not have.
> > Is there a simple fix for this that I could add to my QGIS 1.8 build?
> > If not, Thiago, then reinstall QGIS 1.8-1, this will use the old GDAL
> 1.9 framework which should still be installed, though the GDAL path in
> GdalTools config will still point to the latest GDAL 1.10. For simplicity,
> reinstall GDAL 1.9, that will reset the default GDAL version, yet still
> leave both 1.9 and 1.10 installed. You should probably then reinstall the
> previous GRASS 6.4.2-? (I forget which build version). But, I haven't
> updated my archive in a while so these old versions will be difficult to
> find if you don't have your own backup of them.
> > ... for all that hassle, I hope that the GdalTools can be easily fixed
> to avoid all the downgrading.
> > On Jul 17, 2013, at 5:45 PM, Etienne Tourigny wrote:
> >> I am pretty sure it is due to gdal-1.10. The GdalTools plugin has to
> fixed to support gdal-1.10. Can you try to downgrade to gdal-1.9?
> >> Cheers
> >> Etienne
> >> On Wed, Jul 17, 2013 at 4:46 PM, Thiago V. dos Santos <
> thi_veloso at yahoo.com.br> wrote:
> >> Dear Etienne, Wernner and Giovanni,
> >> Thanks for the feedback. I examined each of your suggestion and I'm
> still not sure on what is causing the lack of some options. Everything is
> enabled, and still the only option I have under raster -> conversion are:
> >> - Translate (convert format)
> >> - RGB to PCT
> >> - PCT to RGB
> >> GDAL Path is configured under gdaltools settings as follows:
> >> /Library/Frameworks/GDAL.framework/Programs:/usr/bin
> >> (just like recommended by the maintaner of the packages for Mac)
> >> Any clue?
> >> Regards,
> >> PhD student
> >> Land and Atmospheric Science
> >> University of Minnesota
> http://www.laas.umn.edu/CurrentStudents/MeettheStudents/ThiagodosSantos/index.htm
> >> Phone: (612) 323 9898
> >> From: Etienne Tourigny <etourigny.dev at gmail.com>
> >> To: Thiago V. dos Santos <thi_veloso at yahoo.com.br>
> >> Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> >> Sent: Wednesday, July 17, 2013 9:33 AM
> >> Subject: Re: [Qgis-user] Rasterize (vector to raster) no longer exists
> >> Hi Thiago!
> >> Is GdalTools plugin available and enabled? Do you see other tools in
> the Raster menu?
> >> cheers mate!
> >> Etienne
> >> On Wed, Jul 17, 2013 at 10:59 AM, Thiago V. dos Santos <
> >> No one?
> >> Yesterday I installed the lates QGIS on my Windows laptop and there
> were all the menus I was used to (including "rasterize", which I was
> looking for). Every little option was available, unlike Mac/Linux version.
> >> Does anybody know why some options are supressed on Mac/Linux version
> of QGIS?
> >> Regards,
> >> PhD student
> >> From: Thiago V. dos Santos <thi_veloso at yahoo.com.br>
> >> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> >> Sent: Friday, July 12, 2013 3:54 PM
> >> Subject: [Qgis-user] Rasterize (vector to raster) no longer exists
> >> Hi everybody,
> >> First post in this list, so please excuse any mistake.
> >> I'm a GIS user on Mac (Mountain Lion) and I have been using using
> latest gdal (1.10) and Qgis (1.8.0-2) provided by Kyng Chaos.
> >> I need to convert a vector to a raster, which previously could be done
> with "rasterize" under the "Raster -> conversion" menu (once the vector was
> loaded). In the past I used this option very often, but I couldn't find it
> today.
> >> Am I missing something or was this option replaced/removed from Qgis?
> >> Greetings,
> >> PhD student
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> > Second Pogril: I don't know. Why IS life like sticking your head in a
> bucket filled with hyena offal?
> > First Pogril: I don't know either. Wretched, isn't it?
> > -HitchHiker's Guide to the Galaxy
> The equator is so long, it could encircle the earth completely once.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130717/1456fe87/attachment.html>
