[Qgis-user] [Qgis-developer] More ideas about package installation in R for SEXTANTE
Victor Olaya
volayaf at gmail.com
Thu Jul 18 00:47:52 PDT 2013
Perfect, then there is no need for changes :-)
Thank you!
2013/7/18 Alexander Bruy <alexander.bruy at gmail.com>:
> No, all paths inside installer are the same as in OSGeo4W, e.g.
> apps, bin, share and all other directories still here. Only absolute
> path may changed, because user can install QGIS in any directory.
> 2013/7/18 Victor Olaya <volayaf at gmail.com>:
>> Oh cool, I didn't know that. Will the path be the same, relative to
>> the QGIS path? now the SAGA path is configured automatically with a
>> fixed relative path, since in OSGeo4W you cannot select where to put
>> the different apps, but if the relative path is different in the
>> standalone installer, it should be check as well
>> Cheers
>> Victor
>>> Hi,
>>> 2013/7/18 Paolo Cavallini <cavallini at faunalia.it>:
>>>>> Are there any plans to put SAGA in the standalone version? That will
>>>>> definitely help users. It might need require some changes in SEXTANTE,
>>>>> though, to have it configured by default
>>>> *Please* do: having it working out of the box will immensely increase usability.
>>>> All the best.
>>> If I'm not wrong, SAGA already in OSGeo4W and marked as dependency for QGIS.
>>> So I think it will be included in standalone installer automatically
>>> because this
>>> installer based on OSGeo4W
>>> Alexander Bruy
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexander Bruy
