[Qgis-user] QGIS rotate entire rendered map
Raymond Nijssen
r.nijssen at terglobo.nl
Sat Jul 20 03:08:40 PDT 2013
Hi Bjorn,
You can rotate your map in the composer only. First, add a map to your
layout. After selecting it you can edit the rotation value in the tab
"Item properties".
I don't know when this feature was added, but it has been in QGIS master
for a while.
Good luck!
Raymond
On 07/20/2013 12:01 PM, Bjorn Nyberg wrote:
> Hej,
> I am slowly trying to move away from arcgis to open source software
> like grass and qgis but there is one feature that I really like in
> arcgis that I cant seem to find in QGIS in my transition. Simply
> enough, i'd like to rotate all layers in the current rendered window
> to say 90degrees relative to north as I map a feature (note I am not
> talking about rotating the final map output as suggested here
> http://gis.stackexchange.com/questions/54060/can-qgis-1-8-0-mac-rotate-the-entire-view-of-a-project).//I
> use this feature quiet a lot in arcgis (data frame properties --
> general -- rotation) to map especially elongated feature at a
> resolution that otherwise won't fit on my screen and I assume that
> there must be something equivalent in qgis that I have simply not noticed.
> Cheers,
> Bjorn
> <cid:part2.04070703.02020502 at gmail.com>
> Qgis-user mailing list
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130720/c64c19f0/attachment.html>
