[Qgis-user] TIN Interpolation
Andreas Neumann a.neumann at carto.net
Wed Jul 24 04:50:20 PDT 2013
Hi Bernd,
You can't - breaklines are only supported if they are 3d files - like 3d
shapes. Often - breaklines are surveyed in the field and each vertex has
a z-value.
In your case - if you only want to use these breaklines without
elevation values - then it is unsupported by the interpolation plugin.
It would be a new feature of the interpolation plugin that does not
exist yet. One can discuss how useful breaklines without elevation
values really are.
You may want to dig into GRASS or SAGA if they support breaklines
without elevation.
Andreas
Am 24.07.2013 12:19, schrieb Bernd Vogelgesang:
> Hi Marco,
> thanx for your answer. But i fear i didn't get the message.
> My main data are elevation points from an ordinary point shape with a z
> attribute.
> I also digitized some peaks from a map and entered their hights in a
> different layer.
> Those two point featured are handled correctly in the interpolation.
> The structure lines I added are simply digitized small streams.
> When adding them to the list of layers, an interpolation attribute is
> chosen from the first available numerical attribute field in that shape
> by default.
> As the lines do not have any information besides their geometry, i
> wonder where i should get values from so the interpolation will work
> correctly.
> I also tried removing all attributes,so no interpolation attribute can
> be picked by the plugin. The lines are then ignored completely.
> When i give the lines some arbitratry value like 1, the interpolation
> produces real canyons, when using higher values than the surrounding
> area, it produces ridges.
> So again the question: how on earth shall i be able to give those lines
> attributes values that will not destroy the interpolation.
> I do not ḱnow the exact elevations of those valley grounds, which is the
> reason why i want to interpolate them!
> Do i have a misconception or does the plugin?
> Cheers
> Bernd
> p.s. Scrrenshot with structure lines with attribute value of 1:
> https://dl.dropboxusercontent.com/u/48666790/QGIS/structurelinesvalue1.png
> Am 24.07.2013, 08:30 Uhr, schrieb Marco Hugentobler
> <marco.hugentobler at sourcepole.ch>:
>> Hi Bernd
>>  >So, how are line features supposed to work in interpolation plugin?
>> Or how can i give structure lines hight values that make sense?
>> Well, somehow you need to say the plugin what the values to
>> interpolate are. Currently possible is to take from attribute or from
>> z-value (for 2.5D geometry types). Where do you have the height values
>> in your data?
>> The line features are used to modify the triangulation. The
>> triangulation is modified such that no edge crosses a breakline or
>> structure line (constrained Delaunay triangulation). The difference
>> between handling of breaklines and structure lines is that cubic
>> interpolation produces a sharp break rather than a continuous one.
>> Please note that the interpolation plugin has some numerical problems
>> in the TIN creation that may lead to crashes (especially for data in
>> degrees). There is the option to dump the generated triangle net, so
>> you can see what the plugin does.
>> Regards,
>> Marco
>> On 23.07.2013 23:44, Bernd Vogelgesang wrote:
>>> Hi folks,
>>> i'm currently playing around with a set of LIDAR points (200m Grid,
>>> but for free).
>>> Trying to "pimp" the model up, i also added some hight points from a
>>> topo-wms and wanted to add break lines and structure lines (streams).
>>> Now i'm a bit clueless about the usage of the line features. The
>>> interpolation plugin always asks for a interpolation attribute, which
>>> doesn't make much sense cause those lines don't have them. They
>>> choice of the attribute field seems automatically limited to
>>> numerical fields (which makes sense for the z-values of points).
>>> When i just create and pick a numerical field without values, the
>>> lines seem not to have any effect on the interpolation. When i use
>>> e.g the id, it has bizarre effects on the outcome.
>>> All tutorials and documentations (e.g.
>>> http://docs.qgis.org/1.8/html/en/docs/user_manual/plugins/plugins_interpolation.html
>>> ) i found on that only cover the unproblematic usage of points and
>>> leave out the lines completely.
>>> Thanx
>>> Bernd
