[Qgis-user] QGIS 1.8 python plugin problem
    ludo
    ludovic.granjon at wanadoo.fr
    Wed Jul 24 05:05:25 PDT 2013
Hi all
When I look on an other install that work perfectly, it seems that when I install python-qgis, this files :
/usr/lib/libqgispython.so.1.8.0
/usr/lib/python2.7/dist-packages/pyspatialite/_spatialite.so
/usr/lib/python2.7/dist-packages/qgis/analysis.so
/usr/lib/python2.7/dist-packages/qgis/core.so
/usr/lib/python2.7/dist-packages/qgis/gui.so
/usr/lib/python2.7/dist-packages/qgis/networkanalysis.so
are not installed on the qgis install problem, I don't know why.
Have you an idea ?
Thanks a lot
Ludovic
> Message du 24/07/13 13:06
> De : "ludo"
> A : Qgis-user at lists.osgeo.org
> Copie à :
> Objet : [Qgis-user] QGIS 1.8 python plugin problem
> Hi all
I just install a new linux mint kde 14 and I try to install qgis 1.8 but I have some problems with python plugin.
When I start QGIS in the log I have :
"Impossible de charger la bibliothèque Python Impossible de charger la bibliothèque /usr/lib/qgispython : (/usr/lib/libqgispython.so: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
And It's right I don't have this file. however python-qgis and python-qgis-common are installed.
I see this kind of problem on mailing list and french forum but no solution worked for me.
Do you have any ideas ?
Thanks a lot
Ludovic
Qgis-user mailing list
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130724/41caf580/attachment.html>
