[Qgis-user] layers not adding properly
Saulteau Don
sault.don at gmail.com
Sun Jul 28 11:33:02 PDT 2013
I'm getting this issue as well on Windows installations from osgeo4w.
I'm noticing it only for the layers that should be added from analysis
tools.
Like whenever you run a tool fom the vector pulldown menu that has the
option to "add resulting layer to map" it doesn't actually appear in the
layer list.
BUT! You if you save and close the qgis project, I can see it in the .qgs
file when I open it in notepad. It has a <mapplayer> entry.
It seems to do this sometimes but not all the time. So it's hard to
reproduce. I'll keep playing with qgis on windows to see if I can figure it
out some more and maybe get some useful logs or screens.
On Sat, Jul 27, 2013 at 12:29 PM, . <expectationlost at gmail.com> wrote:
> using QGIS 1.8.0 lisboa on windows 7 pc
> adding vector layers and they are not adding properly they don't show up
> in the layers list (or anywhere else) but when i use the mmqgis plugin
> to merge all layers they are are listed there.
> they are not 'hidden'.
> it seems to happen when i try to add layers and have control layer render
> order on, because when i turn it off the layers adds fine, but i cannot
> delete the previous layer that didn't add correctly, i can't see them to
> select and remove them
> this is screenshot fwiw http://imgur.com/gkjklPH
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130728/095855cf/attachment.html>
