[Qgis-user] plugin helloworld 1.5
Borys Jurgiel
lists at borysjurgiel.pl
Mon Jul 29 02:41:34 PDT 2013
Dnia poniedziaĆek, 29 lipca 2013 o 07:14:05 Su Hartono napisaĆ(a):
> I use OS Ubuntu 12.04.
> I got "Error loading plugin"
> The plugin is broken. Python said:
> 'module' object has no attribute 'classFactory'.
> How to fix it ?
> -- thank you--
> Suhartono
There is a bug in the plugin so the __init__.py file is empty. Just add
following simple function to it (mind the indentation):
def classFactory(iface):
from HelloWorld import HelloWorld
return HelloWorld(iface)
You can also use that file from the 1.0 version. For more information look at
the PyQGIS cookbook [1].
Btw. note for QGIS 1.8 you need to put plugin metadata to both: __init__.py
and metadata.txt files. From QGIS 2.0 the only place to put the metadata is the
metadata.txt file. The __init__.py should only contain the classFactory
function.
[1] http://www.qgis.org/pyqgis-cookbook/plugins.html#plugins
