[Qgis-user] Rscripts in Sextante - multiple fields?
Victor Olaya volayaf at gmail.com
Tue Jul 30 00:36:55 PDT 2013
> - is it possible to select multiple fields from a layer and use that vector
> of column names in a script?
> ##fields = multiple field layer
There is currently no option for selecting multiple fields. You can
add a string input which can be used to enter a comma-separated list
of field names. Just make sure that you then check that the fields
exist, since the user might enter wrong field names
> - very often the R console output does not work. For example the "Field
> summary statistic" example script sometimes works and sometimes doesnt. I
> have no clue why. Are there any known bugs with the console output?
Can you provide a case where it always fails? that would help debuggin...
> -another question regarding SAGA and Sextante: why do some tools do not
> appear? for example the new SAGA has the VirGa Modules including a nice
> watershed segmentation algorithm which is nice and fast. However, it does
> not appear in the module list. Is there any reason why not all of them
> appear in Sextante?
A module will appear only if a description file exist that tells
SEXTANTE about the syntax needed to call it. Creating a module is
pretty simple, with jut a short text file. Here you have a list of
them.
https://github.com/qgis/Quantum-GIS/tree/master/python/plugins/sextante/saga/description
If you could have a look at some of them and then create the
corresponding descriptions for the VirGa modules, that would be great.
More information about this can be found here.
https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/sextante/grass/grass.txt
Thanks in advance!
