[Qgis-user] CSV Export broken in QGIS 1.8.0 for (at least) Debian Wheezy
Gerardo Jimenez
gejst5 at hotmail.com
Mon Jun 3 19:58:39 PDT 2013
Could be a problem of CRS inconsistency? What I mean is utm defined as lat lon for instance. Usually CRS inconsistency lead to problems...
Gerardo Jiménez Delgado
Instituto de Investigaciones Antropológicas
Universidad Nacional Autónoma de México
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
> To: qgis-user at lists.osgeo.org
> From: andre+joost at nurfuerspam.de
> Date: Mon, 3 Jun 2013 22:06:57 +0200
> Subject: Re: [Qgis-user] CSV Export broken in QGIS 1.8.0 for (at least) Debian Wheezy
> Hi,
> I get the same error if I exort a line geometry with over 3000 vertices
> to CSV, and check "Add to canvas". Unchecking it gives no error message,
> but the CSV file is empty.
> Greetings,
> André Joost
> Am 03.06.2013 21:34, schrieb Micha Silver:
> > On 06/03/2013 08:23 PM, Anonymous Coward wrote:
> >> I checked the data and path and they match the criteria you describe. I also
> >> downgraded from 1.8 to 1.7.5 and still got the same error.
> >> Any place I can get more details of the error?
> >> Thanks
> > How big is the data file? What does it contain? Maybe try with some very simple
> > data. Create a new point shapefile, with just 2 or 3 columns, and try the "Save
> > As..." to CSV. If that works, then perhaps it's something in your data.
> >> On Sun, Jun 2, 2013 at 5:53 AM, Micha Silver<micha at arava.co.il
> >> <mailto:micha at arava.co.il>> wrote:
> >> On 06/01/2013 02:38 AM, Anonymous Coward wrote:
> >>> Each time I try to "Save as.." a vector layer to a CSV file I get an
> >>> (uninformative) error:
> >>> Export to vector file failed.
> >>> Error: creation of data source failed (OGR error:)
> >> Works here, on Wheezy, QGIS 1.8. Check your column names for>10
> >> characters, non-ascii characters, etc. Also, be sure that there are no
> >> spaces or non-ascii characters in the whole path to the shapefile.
> >> Regards,
> >> Micha
> >>> This worked fine in QGIS 1.7
> >>> Any ideas?
> >>> This mail was received via Mail-SeCure System.
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Micha Silver
> > GIS Consultant, Arava Development Co.
> > http://www.surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130603/2d60270b/attachment.html>
