[Qgis-user] Vector to Raster Conversion, was :[Euclidean Distance grid creation problem]
Alex Mandel
tech_dev at wildintellect.com
Tue Jun 4 13:37:29 PDT 2013
Ok, now we're getting somewhere. There error is specifically with the
GDAL rasterize tool (has no direct link to a euclidean distance tool).
Can you please post the GDAL command from the bottom box of that tool?
Thanks,
Alex
On 06/04/2013 01:14 PM, Falk Huettmann wrote:
> thanks, re. Euclidean Distance problem,
> we use the following point layer (shapefile attached) and with the GDAL
> plugin.
> We click on Raster, Rasterize (but get a grey canvas; all values in the
> legend show the same. Using line data has the same effect).
> We cannot proceed from that.
> From there we wanted to get a Euclidean Distance and using Raster, Analyse,
> Distance.
> We got stuck in this for over 3 weeks now (paper on Open Source GIS) and
> wonder how to proceed next and for good
> progress.
> Thanks so much for any insights.
> Very best from Alaska
> F.
> On Mon, Jun 3, 2013 at 9:21 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>> On 06/03/2013 10:02 PM, Falk Huettmann wrote:
>>> Dear all,
>>> greetings;
>>> we are still stuck with creating a Euclidean Distance grid in QGIS
>>> based on point data (shapefile, projected in lat lon and with an ID of 1).
>>> I am aware of the steps shown online, but these create us just a grey
>>> canvas.
>>> (we tried different pixel and extent settings too)
>>> We are grateful for any input (if not resolved, we will probably move to
>>> R
>>> then and other options).
>>> Thanks indeed for any input; more later
>>> Falk Huettmann
>> Grey pixels do not mean no data. Did you check the values of random pixels
>> with the Info tool?
>> Normally in the raster properties you have ask QGIS to calculate the range
>> of values, and stretch min/max in order to actually see what you expect, or
>> put in a custom color ramp.
>> Also what tutorial did you follow and which tool did you use to calculate
>> the distance grid.
>> Thanks,
>> Alex
