[Qgis-user] Spatialite - can't type fields of a view
Régis Haubourg regis.haubourg at eau-adour-garonne.fr
Fri Jun 7 01:37:13 PDT 2013
I found that:
http://sqlite.1065341.n5.nabble.com/Computed-columns-in-VIEWs-return-NULL-but-should-be-able-to-be-typed-Any-ideas-td56769.html#a56770
<http://sqlite.1065341.n5.nabble.com/Computed-columns-in-VIEWs-return-NULL-but-should-be-able-to-be-typed-Any-ideas-td56769.html#a56770>
Its dated from 2010, anyone knows if this has changed ?  Problem occurs with
computed columns.
Workaround would need to modify provider to let it autodetect column type
based on content (unefficient) :
I must point out that this is a great limitation to usage of spatialite when
trying to have graduated classifications.
Régis
View this message in context: http://osgeo-org.1560.x6.nabble.com/Spatialite-can-t-type-fields-of-a-view-tp5058436p5058633.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
