[Qgis-user] QGIS server and fcgi with ubuntu 12.04
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Mon Jun 10 01:37:23 PDT 2013
Hi Andi
FCGI_INCLUDE_DIR /usr/include
FCGI_LIBRARY /usr/lib/libfcgi.so
In /usr/include there are some header files:
fcgiapp.h, fcgi_config.h, fcgimisc.h, fcgio.h, fcgios.h, fcgi_stdio.h
And /usr/lib/libfcgi.so is found.
Regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im
> Auftrag von Andreas Neumann
> Gesendet: Montag, 10. Juni 2013 09:36
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] QGIS server and fcgi with ubuntu 12.04
> Hi Stefan,
> Did you check these paths with ccmake before compiling?
> FCGI_INCLUDE_DIR
> FCGI_LIBRARY
> Maybe checking these paths and rerunning ccmake would help?
> Andreas
> Am 10.06.2013 08:34, schrieb Ziegler Stefan:
> > Hi
> > I have some problems running QGIS server as fcgi with Ubuntu 12.04. "apachectl -t
> -D DUMP_MODULES" shows that the fcgid module ist loaded. But I only get errors when
> trying to run it as fcgi:
> > [Sun Jun 09 21:24:39 2013] [error] [client 37.35.115.249] Premature
> > end of script headers: qgis_mapserv.fcgi, referer:
> > http://www.catais.org/map/grundbuchplan?startExtent=615721,222428,6198
> > 77,226198&visibleLayers=Baulinie,Amtliche%20Vermessung%20(schwarz-weis
> > s),Strassenkarte&format=image%2fpng%3b%20mode%3d8bit
> > [Sun Jun 09 21:24:40 2013] [warn] [client 37.35.115.249]
> > (104)Connection reset by peer: mod_fcgid: error reading data from
> > FastCGI server, referer:
> > When commenting out "AddHandler fcgid-script .fcgi" line from fcgid.conf file it only
> runs as normal cgi and then it's terrible slow. I'm using a self compiled master version
> of QGIS. Had anyone similar problems with ubuntu 12.04? It worked with the same
> configuration with Ubuntu 10.04.
> > Excerpts from virtual host config:
> > ScriptAlias  /cgi-bin/ /home/catais/catais.org/docroot/cgi-bin/
> >  <Directory "/home/catais/catais.org/docroot/cgi-bin">
> >     AllowOverride None
> >     Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
> >     #SetHandler fcgid-script
> >     #AddHandler fcgid-script .fcgi
> >     Order allow,deny
> >     Allow from all
> >     SetEnv LD_LIBRARY_PATH /home/catais/Apps/qgis_master/lib
> > </Directory>
> > Fcgid.conf:
> > <IfModule mod_fcgid.c>
> >   FcgidConnectTimeout 600
> >   FcgidMaxRequestLen 134217728
> >   FcgidMaxProcesses 50
> >   FcgidMinProcessesPerClass 5
> >   FcgidMaxProcessesPerClass 20
> >   ProcessLifeTime 7200
> >   IPCCommTimeout  7200
> >   IPCConnectTimeout 300
> >   FcgidProcessLifeTime 7200
> >   SocketPath /var/lib/apache2/fcgid/sock
> >   FcgidInitialEnv LD_LIBRARY_PATH /home/catais/Apps/qgis_master/lib
> >   FcgidInitialEnv DISPLAY ":0"
> >   FcgidInitialEnv LANG=de_CH.UTF-8
> > </IfModule>
> > Regards
> > Stefan
> > Freundliche Grüsse
> > Stefan Ziegler
> > Leiter amtliche Vermessung
> > Amt für Geoinformation
> > Amtliche Vermessung
> > Rötistrasse 4
> > 4500 Solothurn
> > Telefon +41 32 627 75 96
> > Telefax +41 32 627 75 98
> > stefan.ziegler at bd.so.ch
> > http://www.so.ch
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
