[Qgis-user] QGIS server and fcgi with ubuntu 12.04
    Ziegler Stefan
    Stefan.Ziegler at bd.so.ch
    Mon Jun 10 01:50:48 PDT 2013
Libfcgi-dev is installed.
Regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im
> Auftrag von Marco Hugentobler
> Gesendet: Montag, 10. Juni 2013 10:43
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] QGIS server and fcgi with ubuntu 12.04
> >And /usr/lib/libfcgi.so is found.
> It is part of package libfcgi-dev
> Regards,
> Marco
> On 10.06.2013 10:37, Ziegler Stefan wrote:
> > Hi Andi
> > FCGI_INCLUDE_DIR /usr/include
> > FCGI_LIBRARY /usr/lib/libfcgi.so
> > In /usr/include there are some header files:
> > fcgiapp.h, fcgi_config.h, fcgimisc.h, fcgio.h, fcgios.h, fcgi_stdio.h
> > Regards
> > Stefan
> >> [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Andreas
> >> Neumann
> >> Gesendet: Montag, 10. Juni 2013 09:36
> >> Hi Stefan,
> >> Did you check these paths with ccmake before compiling?
> >> FCGI_INCLUDE_DIR
> >> FCGI_LIBRARY
> >> Maybe checking these paths and rerunning ccmake would help?
> >> Andreas
> >> Am 10.06.2013 08:34, schrieb Ziegler Stefan:
> >>> Hi
> >>> I have some problems running QGIS server as fcgi with Ubuntu 12.04.
> >>> "apachectl -t
> >> -D DUMP_MODULES" shows that the fcgid module ist loaded. But I only
> >> get errors when trying to run it as fcgi:
> >>> [Sun Jun 09 21:24:39 2013] [error] [client 37.35.115.249] Premature
> >>> end of script headers: qgis_mapserv.fcgi, referer:
> >>> http://www.catais.org/map/grundbuchplan?startExtent=615721,222428,61
> >>> 98
> >>> 77,226198&visibleLayers=Baulinie,Amtliche%20Vermessung%20(schwarz-we
> >>> is s),Strassenkarte&format=image%2fpng%3b%20mode%3d8bit
> >>> [Sun Jun 09 21:24:40 2013] [warn] [client 37.35.115.249]
> >>> (104)Connection reset by peer: mod_fcgid: error reading data from
> >>> FastCGI server, referer:
> >>> 98
> >>> When commenting out "AddHandler fcgid-script .fcgi" line from
> >>> fcgid.conf file it only
> >> runs as normal cgi and then it's terrible slow. I'm using a self
> >> compiled master version of QGIS. Had anyone similar problems with
> >> ubuntu 12.04? It worked with the same configuration with Ubuntu 10.04.
> >>> Excerpts from virtual host config:
> >>> ScriptAlias  /cgi-bin/ /home/catais/catais.org/docroot/cgi-bin/
> >>>   <Directory "/home/catais/catais.org/docroot/cgi-bin">
> >>>      AllowOverride None
> >>>      Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
> >>>      #SetHandler fcgid-script
> >>>      #AddHandler fcgid-script .fcgi
> >>>      Order allow,deny
> >>>      Allow from all
> >>>      SetEnv LD_LIBRARY_PATH /home/catais/Apps/qgis_master/lib
> >>> </Directory>
> >>> Fcgid.conf:
> >>> <IfModule mod_fcgid.c>
> >>>    FcgidConnectTimeout 600
> >>>    FcgidMaxRequestLen 134217728
> >>>    FcgidMaxProcesses 50
> >>>    FcgidMinProcessesPerClass 5
> >>>    FcgidMaxProcessesPerClass 20
> >>>    ProcessLifeTime 7200
> >>>    IPCCommTimeout  7200
> >>>    IPCConnectTimeout 300
> >>>    FcgidProcessLifeTime 7200
> >>>    SocketPath /var/lib/apache2/fcgid/sock
> >>>    FcgidInitialEnv LD_LIBRARY_PATH /home/catais/Apps/qgis_master/lib
> >>>    FcgidInitialEnv DISPLAY ":0"
> >>>    FcgidInitialEnv LANG=de_CH.UTF-8
> >>> </IfModule>
> >>> Regards
> >>> Stefan
> >>> Freundliche Grüsse
> >>> Stefan Ziegler
> >>> Leiter amtliche Vermessung
> >>> Amt für Geoinformation
> >>> Amtliche Vermessung
> >>> Rötistrasse 4
> >>> 4500 Solothurn
> >>> Telefon +41 32 627 75 96
> >>> Telefax +41 32 627 75 98
> >>> stefan.ziegler at bd.so.ch
> >>> http://www.so.ch
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions Weberstrasse 5, CH-8004 Zürich,
> Switzerland marco.hugentobler at sourcepole.ch http://www.sourcepole.ch Technical
> Advisor QGIS Project Steering Committee
