[Qgis-user] SpatiaLite views
Antonio Vico avicomartin at gmail.com
Mon Jun 10 14:29:39 PDT 2013
I get problems in spatialite views too. I created views in spatialitegui
follow the same instructions and I can open the view in qgis but if I
try to open Attribute table, in all values get "ERROR" (in qgis ubuntu
12.04 from http://qgis.org/debian-nightly and in osgeo4w (1.8 and
1.9-dev versions).
I posted this question in a previous post but only Goyo commented, and I
can't get a solution.
Sorry if this not solve your problem.
On 10/06/13 14:01, Andreas Neumann wrote:
> Hi,
> I wanted to create a view with spatial data in SpatiaLite. I can create
> the view by hand in DB-Manager and I created entries in the
> "views_geometry_columns" table.
> But when I add the view it is always added as a non-geometry table
> containing only attributes but no geometry.
> Am I missing additional entries in some metadata table?
> I tried to follow the instructions here:
> http://www.gaia-gis.it/gaia-sins/spatialite-cookbook/html/sp-view.html -
> but it does not work as described here.
> I can add the table from the view but all I get is no geometry and
> "Error" content in every cell.
> I am using the current QGIS master.
> Thank you if you have any idea how to correctly manage views in SpatiaLite.
> Andreas
> Qgis-user mailing list
