[Qgis-user] creation of .gpx is not straightforward
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu Jun 13 02:18:45 PDT 2013
+1 for a bit more user-friendly save as...-dialog in general.
The problem with the creation options does not only apply to GPX (which
might be one of the most common formats), but also for KML, CSV, you name
it.
Once a user understood what the data source and layer fields are meant for
and where to search for additional infos, the tool is really powerful.
But i fear that 90% of the users get lost on the way:
First a user has to realize that he needs those creations options when
something does not work as expected.
Then he has to click on the Help-Button to get the general informations
which he is not looking for.
Then he has to scroll down to find the tiny link telling about the
supported OGR vector formats: http://gdal.org/ogr/ogr_formats.html
There he has to search for the desired format and click the link (for GPX
http://www.gdal.org/ogr/drv_gpx.html)
There he has to scroll down some screens to find the creation options
(called Creation Issues there)
Finally, he has to understand what the fuzz is all about, what is
necessary and what is just optional etc etc.
Because most people wont use that on a daily basis, they will just forget
about the procedure and have to start the exploration from the beginning
when facing problems.
I fear there is no easy way of presenting the options, otherwise our
ingenious developers would have already introduced something.
IMO work on this topic is really needed, cause not knowing the caveats of
these procedures causes many frustrations, troubles and bizarre
workarounds to get things done while under the hood, a powerful machine is
waiting ...
Cheers
Bernd
Am 13.06.2013, 08:01 Uhr, schrieb Andre Joost <andre+joost at nurfuerspam.de>:
> +1 from me. Output CRS should be set to EPSG:4326 by default as well.
> I think this could be an easy way to start writing an own plugin, but I
> currently wait for the next QGIS version for that. There were some
> greater changes announced for the plugin API (and I don't have any
> knowledge in python programming yet).
> Greetings,
> André Joost
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
