[Qgis-user] Select single feature(s)
    Andreas Neumann
    a.neumann at carto.net
    Wed Jun 19 23:42:58 PDT 2013
 Did it really work at all? I never had a working system when render
 cache was enabled. But I figured out that this was due to WMS layers. I
 often have combinations of Postgis layers and WMS layers. A typical
 situation where the render-cache would be useful if it worked.
 When the multi-threading work will be continued (hopefully in QGIS 2.1)
 the whole rendering process will be reworked anyway and the render-cache
 would have to be revisited/reworkd or canceled anyway.
 When render cache was enabled I often had out-of-sync layer visiblity
 in the layer tree.
 Andreas
 On Thu, 20 Jun 2013 07:48:58 +1000, Nathan Woodrow wrote:
> I wonder why we are now having issues with render caching.  It used
> to work fine in the older versions.
> - Nathan
>  On Thu, Jun 20, 2013 at 1:04 AM, Andreas Neumann  wrote:
>> Hi,
>> render cache introduces a lot of issues and will probably be
>> removed in
>> QGIS 2.0 (or well-hidden).
>> I always recommend to disable it.
>> Andreas
>> Am 19.06.2013 17:02, schrieb Lene Fischer:
>>> Sorry to disturb again
>> > Just changed a few general options - Use render Caching - When I
>> disable this feature, select works again.
>> > Still - is it a feature?
>> > Regards
>> > Lene Fischer
>> > ________________________________________
>> > Fra: qgis-user-bounces at lists.osgeo.org [1]
>> [qgis-user-bounces at lists.osgeo.org [2]] på vegne af Lene
>> Fischer [lfi at life.ku.dk [3]]
>> > Sendt: 19. juni 2013 16:58
>> > Til: qgis-user at lists.osgeo.org [4]
>> > Emne: [Qgis-user] Select single feature(s)
>> > Hi
>> > Downloaded newest weekly build - and trying to select two
>> polygons by combining 'select single feature' and CTRL.
>> > But with no success. only one polygon at the time. Is it a
>> feature or a bug?
>> > Regards
>> > Lene Fischer
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org [5]
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user [6]
>> > Qgis-user at lists.osgeo.org [7]
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user [8]
>> Qgis-user at lists.osgeo.org [9]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [10]
> Links:
> [1] mailto:qgis-user-bounces at lists.osgeo.org
> [2] mailto:qgis-user-bounces at lists.osgeo.org
> [3] mailto:lfi at life.ku.dk
> [4] mailto:qgis-user at lists.osgeo.org
> [5] mailto:Qgis-user at lists.osgeo.org
> [6] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [7] mailto:Qgis-user at lists.osgeo.org
> [8] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [9] mailto:Qgis-user at lists.osgeo.org
> [10] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [11] mailto:a.neumann at carto.net
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
