[Qgis-user] QGIS Master dependency problem.
Vincent Damoy
vincent.damoy at espaces-naturels.fr
Mon Jun 24 02:57:12 PDT 2013
Hello,
I had the same problem with QGIS on Ubuntu 12.04 (at work, but not at
home :-O ).
Apparently, there is a typo in this file :
/usr/share/qgis/python/plugins/GdalTools/tools/doPolygonize.py, at line 108
" if self.fieldCheck.isChecked() and self.fieldEdit.text()):"
the opening parenthesis lacks.
Il should be :
"if *(*self.fieldCheck.isChecked() and self.fieldEdit.text()):"
I've corrected this typo, then uptaded problematic packages (especially
python-qgis-common).
There was no problem any more with updates.
Hope this helps!
Regards,
Vincent
Vincent Damoy - Responsable SIG
Conservatoire d'Espaces Naturels du Nord et du Pas-de-Calais
152 bd de Paris - 62190 Lillers
Tél : 03.21.54.75.00 - Fax : 03.21.54.56.07
/*Pour adhérer au Conservatoire :*
www.cen-npdc.org/nous-rejoindre/adherent.html/
/Pour le respect de l'environnement, n'imprimez ce message qu'en cas de
nécessité !/
Le 22/06/2013 10:12, Nick Hopton a écrit :
> QGIS Master from the nightly repository, Ubuntu 12.04 (amd64).
> Hi All,
> There were problems with this morning's upgrade (and yesterday's too) with
> python-qgis-common and python-qgis:
> pycentral: pycentral pkginstall: error byte-compiling files (549)
> dpkg: error processing python-qgis-common (--configure):
> subprocess installed post-installation script returned error exit status 1
> dpkg: dependency problems prevent configuration of python-qgis:
> python-qgis depends on python-qgis-common (=
> 1.9.0+git20130618+59fd5e0~precise1); however:
> Package python-qgis-common is not configured yet.
> dpkg: error processing python-qgis (--configure):
> dependency problems - leaving unconfigured
> No apport report written because the error message indicates it's a
> follow-up error from a previous failure.
> Errors were encountered while processing:
> python-qgis-common
> python-qgis
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> Regards,
> Nick.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Master-dependency-problem-tp5061716.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130624/314cd156/attachment.html>
