[Qgis-user] QGIS Server GetMap request displays data but QGIS Web Client does not
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Jun 25 22:46:42 PDT 2013
Hi ?,
I realized the following:
The GetMap request issued by QWC [1] contains only VIEWS_2 for the
LAYERS parameter. When issuing GetProjectSettings [2] (as QWC does) I
find <LayerDrawingOrder>VIEWS_2,Project1,Site,Project2</LayerDrawingOrder>
in the XML doc returned. Maybe you should either
1) set useGetProjectSettings = false in GlobalOptions.js or
2) uncheck "Control rendering order" in "layer order" in your project
and see if any of these helps.
Bernhard
[1]
http://gis.idn12.com/qgis/qgis_mapserv.fcgi?map=C:/projects/t4.qgs&LAYERS=VIEWS_2&FORMAT=image%2Fpng&DPI=96&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A3005&BBOX=2.3283064365387e-10,570943.95280238,2100000,1529056.0471976&WIDTH=1017&HEIGHT=464
[2]
http://gis.idn12.com/qgis/qgis_mapserv.fcgi?map=C:/projects/t4.qgs&&_dc=1372224923641&SERVICE=WMS&VERSION=1.3&REQUEST=GetProjectSettings
Am 26.06.2013 05:53, schrieb cdp:
> Hi all,
> Started having a strange issue out of nowhere on a relatively stable
> installation of QGIS Server and Web Client. The installation is old,
> however it worked perfectly up until recently.
> Problem:
> Layer data visible when doing a Get Map request directly to the QGIS Server
> is not visible when accessing the qgis project via the web client. As an
> example the following links take you to a test qgs project.
> QGIS server get map:
> http://gis.idn12.com/qgis/qgis_mapserv.fcgi?map=c:/projects/t4.qgs&LAYERS=VIEWS_2,project1,site,project2&FORMAT=image/png&DPI=150&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:3005&BBOX=0,400000,2100000,1700000&WIDTH=1200&HEIGHT=1200
> QGIS web client (give it a moment to load..the imagery layer 'VIEWS_2' is
> quite large)
> http://gis.idn12.com/qgiswebclient.html?map=C:/projects/t4.qgs&format=image/png&startExtent=0,400000,2100000,1700000
> There are no scale dependent visability restrictions and all data is in the
> same coordinate system.
> The issue is occurring sporadically across all of our existing .qgs projects
> (which all previously worked perfectly)
> Totally stumped! Any ideas where to start? Would I be correct in saying
> this is a web client issue given that the GetMap request works fine?
> thanks in advance!
> C
> View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Server-GetMap-request-displays-data-but-QGIS-Web-Client-does-not-tp5062214.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> __________ Information from ESET Mail Security, version of virus signature database 8489 (20130625) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
http://www.eset.com
