[Qgis-user] Public transportation maps
Olivier Dalang
olivier.dalang at gmail.com
Mon Mar 4 08:55:24 PST 2013
Hi !
Does any of you have some experience in creating public transportation maps
(bus) with QGis ?
The main problem I have is representing superposed lines with an offset (as
here : http://www.cuk.ch/images/articles/3714/tpg_plan.jpg )
For the sake of editability and multi-scale display, I'd like to use "line
offset" rather than actually offsetting the lines.
One solution would be to offset each bus line of a different amount, but
then, when not superposed, the bus line would display beside the road...
It seems line offset can't be data-defined... Is there a workaround ?
Thanks !!
Olivier
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130304/7a1d57b0/attachment.html>
