[Qgis-user] problems to split images
José Pedro Santos zpsantos1 at hotmail.com
Tue Mar 5 00:43:58 PST 2013
I Jan,
Thanks for making the script. If you want another you a algorithm to split the images you can use Orfeotoolbox in Sextante plugin. At least you save a lot of work instead of complete the script.
Best Regards,
Jose Santos
> Date: Mon, 4 Mar 2013 14:58:13 +0100
> From: osm at tappenbeck.net
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] problems to split images
> hi !
> i try to split a image into 4 new tiles by gdal_translate - the problem
> is, that there was a border between the image in right-axis.
> i create a little script for the work:
> #!/bin/sh
> #gdal_translate -projwin 360623.459101 5685603.57034 362500.0 5683500.0
> -of GTiff
> E:\datenlager_TAP\20130218_XXXXXX_RasterbildTransformation_GK2ETRS\ETRS\1988\1988.tif
> E:/datenlager_TAP/20130218_XXXXXX_RasterbildTransformation_GK2ETRS/ETRS/1988/1988_1.tif
>    # Pfad-Angabe NICHT auf / endent!!!!
> basic_path="E:/datenlager_TAP/20130218_XXXXXX_RasterbildTransformation_GK2ETRS/ETRS"
>    source_theme="1988"
>    source_path=${source_theme}
>                                                  or_rechts="364769.1"
>                                                  or_hoch="5685564.3"
>    #   |       Bild 1         |       Bild 2         +
>    #   |        Bild 3        |       Bild 4         +
> ul_rechts="360638.4"
> ul_hoch="5681411.1"
> # Trennpunkt in der Mitte
> m_rechts="362500.00"
> m_hoch="5683500.00"
>    source="$basic_path/$source_path/$source_theme"
>    echo
>    echo Name der Rasterbilddatei: ${source}.tif
>    echo
>    echo
>    echo THEMA: ${theme}
>    echo Bild 1
>    echo "${ul_hoch} - ${or_hoch} | ${m_rechts} - ${m_hoch}"
>    gdal_translate -projwin ${ul_rechts} ${or_hoch} ${m_rechts} ${m_hoch}
> -of GTiff ${source}.tif ${source}_1.tif
>    echo Bild 2
>    echo "${m_rechts} - ${or_hoch} | ${or_rechts} - ${m_hoch}"
>    gdal_translate -projwin ${m_rechts} ${or_hoch} ${or_rechts} ${m_hoch}
> -of GTiff ${source}.tif ${source}_2.tif
>    echo Bild 3
>    echo "${ul_rechts} - ${m_hoch} | ${m_rechts} - ${ul_hoch}"
>    gdal_translate -projwin ${ul_rechts} ${m_hoch} ${m_rechts} ${ul_hoch}
> -of GTiff ${source}.tif ${source}_3.tif
>    echo Bild 4
>    echo "${m_rechts} - ${m_hoch} | ${or_rechts} - ${ul_hoch}"
>    gdal_translate -projwin ${m_rechts} ${m_hoch} ${or_rechts} ${ul_hoch}
> -of GTiff ${source}.tif ${source}_4.tif
>    echo finish
>    echo
>    done
> here is the log:
> THEMA:
> Bild 1
> 5681411.1 - 5685564.3 | 362500.00 - 5683500.00
> Input file size is 6815, 6831
> Computed -srcwin 57 132 2975 3299 from projected window.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> Bild 2
> 362500.00 - 5685564.3 | 364769.1 - 5683500.00
> Computed -srcwin 3033 132 3627 3299 from projected window.
> Bild 3
> 360638.4 - 5683500.00 | 362500.00 - 5681411.1
> Computed -srcwin 57 3431 2975 3339 from projected window.
> Bild 4
> 362500.00 - 5683500.00 | 364769.1 - 5681411.1
> Computed -srcwin 3033 3431 3627 3339 from projected window.
> finish
> a image with the border you can find at (scale 1:500):
> http://www.tappenbeck.net/qgis/jt_qgis_border_20130304.jpg
> final some informations about the
> ****** images 1 ****
> Driver: GTiff/GeoTIFF
> Files:
> E:/datenlager_tappenbeck/20130218_Wuelfrath_RasterbildTransformation_GK2ETRS/ETRS/1988/1988_1.tif
> Size is 2975, 3299
> Coordinate System is:
> PROJCS["ETRS89 / UTM zone 32N",
>      GEOGCS["ETRS89",
>          DATUM["European_Terrestrial_Reference_System_1989",
>              SPHEROID["GRS 1980",6378137,298.2572221010002,
>                  AUTHORITY["EPSG","7019"]],
>              AUTHORITY["EPSG","6258"]],
>          PRIMEM["Greenwich",0],
>          UNIT["degree",0.0174532925199433],
>          AUTHORITY["EPSG","4258"]],
>      PROJECTION["Transverse_Mercator"],
>      PARAMETER["latitude_of_origin",0],
>      PARAMETER["central_meridian",9],
>      PARAMETER["scale_factor",0.9996],
>      PARAMETER["false_easting",500000],
>      PARAMETER["false_northing",0],
>      UNIT["metre",1,
>          AUTHORITY["EPSG","9001"]],
>      AUTHORITY["EPSG","25832"]]
> Origin = (360637.965654098020000,5685564.494013113000000)
> Pixel Size = (0.625645628251233,-0.625645628251233)
> Metadata:
>    AREA_OR_POINT=Area
> Image Structure Metadata:
>    INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  360637.966, 5685564.494) (  7d 0' 2.63"E, 51d18'15.52"N)
> Lower Left  (  360637.966, 5683500.489) (  7d 0' 5.53"E, 51d17' 8.75"N)
> Upper Right (  362499.261, 5685564.494) (  7d 1'38.70"E, 51d18'17.15"N)
> Lower Right (  362499.261, 5683500.489) (  7d 1'41.56"E, 51d17'10.38"N)
> Center      (  361568.614, 5684532.492) (  7d 0'52.11"E, 51d17'42.96"N)
> Band 1 Block=2975x1 Type=Byte, ColorInterp=Red
>    Mask Flags: PER_DATASET ALPHA
> Band 2 Block=2975x1 Type=Byte, ColorInterp=Green
> Band 3 Block=2975x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=2975x1 Type=Byte, ColorInterp=Alpha
> ****** images 2 ****
> Files:
> E:/datenlager_tappenbeck/20130218_Wuelfrath_RasterbildTransformation_GK2ETRS/ETRS/1988/1988_2.tif
> Size is 3627, 3299
>      GEOGCS["ETRS89",
>      UNIT["metre",1,
> Origin = (362499.887043773720000,5685564.494013113000000)
> Metadata:
>    AREA_OR_POINT=Area
>    INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  362499.887, 5685564.494) (  7d 1'38.73"E, 51d18'17.16"N)
> Lower Left  (  362499.887, 5683500.489) (  7d 1'41.59"E, 51d17'10.38"N)
> Upper Right (  364769.104, 5685564.494) (  7d 3'35.85"E, 51d18'19.11"N)
> Lower Right (  364769.104, 5683500.489) (  7d 3'38.67"E, 51d17'12.34"N)
> Center      (  363634.495, 5684532.492) (  7d 2'38.71"E, 51d17'44.75"N)
> Band 1 Block=3627x1 Type=Byte, ColorInterp=Red
> Band 2 Block=3627x1 Type=Byte, ColorInterp=Green
> Band 3 Block=3627x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=3627x1 Type=Byte, ColorInterp=Alpha
> can someone help me to close the border...
> regards Jan :-)
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130305/36b2a235/attachment.html>
