[Qgis-user] Convert a shapefile to KML in QGIS
G. Allegri giohappy at gmail.com
Thu Mar 7 03:26:05 PST 2013
Sorry, I didn't read carefully.
You can do it using the Save As layer's contextual menu entry. Choose KML
from the top dropdown menu.
giovanni
2013/3/7 António Rocha <toyze.rocha at gmail.com>
> Hello Giovanni
> My intention is not to open but to convert shapefile to KML in QGIS (and
> creating a KML file).
> Thank you.Regards
> Antonio
> On Thu, Mar 7, 2013 at 11:19 AM, G. Allegri <giohappy at gmail.com> wrote:
>> Yuo can oper KML files as you would do with a Shapefile.
>> Verify to choose the right extension in the Open File dialog (on the
>> right side of the file name field), otherwise you won't see the .kml files.
>> giovanni
>>>  Greetings
>>> I want to convert a Shapefile to KML in QGIS (without having to run GDAL
>>> in command lines). How can I do this?
>>> Regards,
>>> Antonio
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giovanni Allegri
>> website: http://giovanniallegri.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130307/7c5e2af1/attachment.html>
