[Qgis-user] Offline editing plugin error
Nomeneta Saili
nome.saili at gmail.com
Thu Mar 7 14:40:09 PST 2013
Hi Giovanni,
Thanks for the information. I am using version 1.8. Yes i tried it with
version 1.7 and it worked. With 1.8 though if i edit a few it can work as
well. I guess the offline plugin does not work fully for 1.8 which is a
shame. It's a wonderful tool for us that need to go out to the field.
Thanks again for the help.
Regards,
Nome
On Fri, Mar 8, 2013 at 3:49 AM, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: Convert a shapefile to KML in QGIS (Sergio Vignali)
> 2. Re: Convert a shapefile to KML in QGIS (G. Allegri)
> 3. Re: Qgis-user Digest, Vol 85, Issue 14 (Wesley Roberts)
> 4. Re: Offline editing plugin error (Giovanni Manghi)
> 5. QGIS 1.8 - using wms with tiles option drops transparent=true
> from request (Duarte Carreira)
> 6. Re: QGIS 1.8 - using wms with tiles option drops
> transparent=true from request (Duarte Carreira)
> Message: 1
> Date: Thu, 7 Mar 2013 12:25:48 +0100
> From: Sergio Vignali <vignalisergio30 at gmail.com>
> To: Ant?nio Rocha <toyze.rocha at gmail.com>
> Cc: Qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Convert a shapefile to KML in QGIS
> Message-ID:
> <CALLUJBZ_kyz6tuHPEEkbKWMsiXC3jwdcuapao=VFh=
> FKs_5u6g at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi,
> simply right click on the layer and after save as,
> after that you can choose the references system and the file format!
> Regards
> 2013/3/7 Ant?nio Rocha <toyze.rocha at gmail.com>
> > Greetings
> > I want to convert a Shapefile to KML in QGIS (without having to run GDAL
> > in command lines). How can I do this?
> > Regards,
> > Antonio
> Sergio Vignali
> CERM Centro Rapaci Minacciati
> (Endangered Raptors Centre)
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130307/6f13284a/attachment-0001.html
> Message: 2
> Date: Thu, 7 Mar 2013 12:26:05 +0100
> From: "G. Allegri" <giohappy at gmail.com>
> Message-ID:
> <CAB4g1=zPd6c-1JBJo0ApZXRxjJVWb4DA8p=
> 3xbDScCATZBZ4bg at mail.gmail.com>
> Sorry, I didn't read carefully.
> You can do it using the Save As layer's contextual menu entry. Choose KML
> from the top dropdown menu.
> giovanni
> > Hello Giovanni
> > My intention is not to open but to convert shapefile to KML in QGIS (and
> > creating a KML file).
> > Thank you.Regards
> > Antonio
> > On Thu, Mar 7, 2013 at 11:19 AM, G. Allegri <giohappy at gmail.com> wrote:
> >> Yuo can oper KML files as you would do with a Shapefile.
> >> Verify to choose the right extension in the Open File dialog (on the
> >> right side of the file name field), otherwise you won't see the .kml
> files.
> >> giovanni
> >>> Greetings
> GDAL
> >>> Regards,
> >>> Antonio
> >> Giovanni Allegri
> >> website: http://giovanniallegri.it
> >> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Giovanni Allegri
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130307/7c5e2af1/attachment-0001.html
> Message: 3
> Date: Thu, 7 Mar 2013 14:00:57 +0200
> From: Wesley Roberts <jwesroberts at gmail.com>
> To: Bernd Laskowski <Bernd.Laskowski at reichshof.de>
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Qgis-user Digest, Vol 85, Issue 14
> Message-ID:
> <CAFik=
> FesGHMUsCUJ95CpQQ2d-Ucubc_xH5hT-TdWcQycnf1X-A at mail.gmail.com>
> Hi Bernd,
> You will need to convert your GPS data to decimal degrees before importing
> the data into QGIS. Do that here (http://bit.ly/Xsh7u8). Once you have
> done
> that replace the deg min sec with the decimal degrees, save your data as a
> *.csv file and import into qgis. This tutorial will help
> http://bit.ly/XshmWh
> Regards,
> Wesley
> On Thu, Mar 7, 2013 at 10:28 AM, Bernd Laskowski <
> Bernd.Laskowski at reichshof.de> wrote:
> > Hi all,
> > how can i input/import a table within hour/minute/second koordinates like
> > Objekt Standort
> > GPS-Daten
> > Bank Am Aggerberg
> > 50?58'40''N/7?44'43''O
> > Schutzh?tte Wandererparkplatz Silberkuhle, Hespert
> > 50?57'43''N/7?44'47''O
> > Schutzh?tte Silberkuhle
> > 50?58'38''N/7?44'45''O
> > Sch?tzh?tte Einfahrt Hochbeh?lter Silberkuhlellmann
> > 50?58'40''N/7?45'36''O
> > usually i use the EPSG-Code 25832 (UTM, ETRS89, Zone 32)
> > Regards
> > Bernd
> Dr Wesley Roberts
> Cell: +27(0)83 5355 646
> skype: roberts-w
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130307/2f7c9240/attachment-0001.html
> Message: 4
> Date: Thu, 7 Mar 2013 13:29:07 +0000
> From: Giovanni Manghi <giovanni.manghi at faunalia.pt>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Offline editing plugin error
> Message-ID:
> <CACfnYnQ26K0SU=
> AC_hggujX3ufpKPAy042t6xJZhYrGaoaUZHw at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi,
> what qgis version are you using, from what I can see in qgis
> 1.8/master the tool is pretty much broken (it works on qgis 1.7.4)
> http://hub.qgis.org/issues/6146
> cheers
> -- Giovanni --
> > Hi Guys,
> > Been using this wonderful plugin for a while now but recently i have been
> > having problems when syncronising my data back to my postGIS database.
> > When i sync it this error props up
> > ERROR:244 Attribute value(s) changes not applied
> > Provider errors:
> > PostGIS errors while changing attributes: ERROR: invalid input syntax
> > for integer
> > LINE1:UPDATE "EPC_ASSETS". "EPC_POLE" SET "TELCO_COUNT" = " WHERE = "f...
> Message: 5
> Date: Thu, 7 Mar 2013 13:23:30 +0000
> From: Duarte Carreira <DCarreira at edia.pt>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] QGIS 1.8 - using wms with tiles option drops
> Message-ID:
> A2C5C1FEBB05AA41A13D4F312D5F1A882DEB28B6 at AMSPRD0710MB365.eurprd07.prod.outlook.com
> Content-Type: text/plain; charset="us-ascii"
> Hi.
> I'm getting this behaviour when loading a wms layer while setting tile
> size. This is a non-tiled service. I'm setting this option so I can print
> within the maximum image size limits imposed by the wms server.
> You can see this by setting a background color, pink for example.
> Loading the wms layer with tiles covers the pink background.
> Loading the same wms layer without setting the tiles size gives me a white
> transparent background and I can see the pink background. This is the
> correct expected behavior.
> Using Fiddler I can see that with tiles the requests don't have
> &TRANSPARENT=TRUE appended anymore.
> I'm using build f440b60.
> Can someone else reproduce this?
> Thanks,
> Duarte Carreira
> Duarte Carreira
> Diretor | Dep. Informa??o Geogr?fica e Cartografia
> www.edia.pt<http://www.edia.pt>
> Tel. +351 284315100
> [http://www.edia.pt/edia/images/edia_logo2.gif]<http://www.edia.pt>
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130307/87665aa8/attachment-0001.html
> Message: 6
> Date: Thu, 7 Mar 2013 13:34:34 +0000
> Subject: Re: [Qgis-user] QGIS 1.8 - using wms with tiles option drops
> Message-ID:
> A2C5C1FEBB05AA41A13D4F312D5F1A882DEB28E4 at AMSPRD0710MB365.eurprd07.prod.outlook.com
> I forgot to mention I have a workaround that works when there is no
> redirection on the wms server...
> You can set the following options on the wms connection properties:
> 1) Append this to the wms url "?TRANSPARENT=TRUE" or
> "&TRANSPARENT=TRUE" if your url already has more parameters
> 2) Check the option "Ignore GetMap URI reported in capabilities"
> This works fine only if your capabilities doc does not point to some other
> location than the wms url you defined in the connection...
> Duarte
> De: Duarte Carreira
> Enviada: quinta-feira, 7 de Mar?o de 2013 13:23
> Para: 'qgis-user at lists.osgeo.org'
> Assunto: QGIS 1.8 - using wms with tiles option drops transparent=true
> from request
> Hi.
> Thanks,
> Duarte Carreira
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130307/d368519d/attachment.html
> End of Qgis-user Digest, Vol 85, Issue 17
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130308/6510df70/attachment.html>
