[Qgis-user] Executing qgis after building from git results in errors and warnings
Eric Goddard
egoddard1010 at gmail.com
Fri Mar 8 05:14:50 PST 2013
For the python console, you need to install qscintilla. On 12.10 I
installed libqscintilla2-dev and python-qscintilla2. The dev package may
not be needed, but it works for me.
The python libraries are located in the $INSTALLPATH/share/qgis/python
directory. Add that directory to your python path to import pyspatialite
outside of QGIS. From within a python script you can :
import sys
sys.path.append(r"/home/tgrossen/Apps/QGIS/share/qgis/python")
from pyspatialite import dbapi2 as db
Hope that helps.
Eric
On Feb 11, 2013 9:22 AM, "Timo Grossenbacher" <wnstnsmth at yahoo.com> wrote:
> I built the latest QGIS version on Ubuntu 12.04, following exactly these
> steps:
> http://www.qgis.org/api/INSTALL.html#toc3
> The only things I changed in ccmake .. were setting
> CMAKE_INSTALL_PREFIX=/home/tgrossen/Apps/QGIS and WITH_PYSPATIALITE=ON
> Before make install, I conducted tests with make test:
> 93% tests passed, 4 tests failed out of 57
> Total Test time (real) = 297.32 sec
> The following tests FAILED:
> 9 - qgis_rasterlayertest (Failed)
> 28 - qgis_composerhtmltest (Failed)
> 41 - PyQgsRasterLayer (Failed)
> 51 - PyQgsComposerMap (Failed)
> Errors while running CTest
> make: *** [test] Error 8
> As you can see, make test itself crashed.
> After make install, I also had to do this:
> http://hub.qgis.org/wiki/quantum-gis/Building_QGIS_from_Source, which
> fortunately worked.
> Anyway,there are several things that are weird when executing the qgis
> binary:
> tgrossen at tgrossen-VirtualBox:~/Apps/QGIS/bin$ ./qgis
> Warning: loading of qgis translation failed
> [/home/tgrossen/Apps/QGIS/share/qgis/i18n//qgis_en_US]
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> And then, after the desktop has loaded, I want to open up a Python shell,
> but that's what I get:
> exceptions.ImportError: No module named Qsci
> 1. Question: What do I have to do in order to use the Python console?
> 2. Question: I explicitly compiled pyspatialite, now where do I find this
> library and how can I include into my regular Python path, so I can use it
> outside of QGIS too?
> wnstnsmth.net
> http://osgeo-org.1560.n6.nabble.com/Executing-qgis-after-building-from-git-results-in-errors-and-warnings-tp5033486.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130308/1affcead/attachment.html>
