[Qgis-user] Problems with data types in joined tables
Albin Blaschka albin.blaschka at standortsanalyse.net
Wed Mar 13 03:37:36 PDT 2013
Hi!
Not a direct answer to your question, but an alternative:
What if you do the join on the database-level in making a view in
Postgres and using the view?
greetings,
Albin
Am 13.03.2013 10:59, schrieb Antonio Vico:
> Hi,
> I am testing with joined tables and I have a problem with data types
> when make a query in Attributes Table.
> This is the situation:
> In a Postgres/Postgis I have two tables, one with geographyc information
> and another with data but without geographyc fiel (relationed both with
> a fiel). I connect to server and import this two tables and join without
> problems. Data structure in joined table seem correct but when I open
> the Attribute Table ant try to make a query, the beaviour in not
> correct. Beaviour in field with integer types are like text and query
> result are wrong.
> I have tested this situation whit gvSIG (for determine if errors are due
> to data structure) but resutls in gvSIG are correct.
> Has somebody the same problem?
> Qgis-user mailing list
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info * www.thinkanimal.info *
| - It's hard to live in the mountains, hard but not hopeless!
