[Qgis-user] convert UTM_UPS data from gps to decimal degrees
Bernd Laskowski
Bernd.Laskowski at Reichshof.de
Wed Mar 13 07:28:32 PDT 2013
I tryed again with milliseconds but the result is nearly the same.
The real Point is about 80 km away.
The UTM UPS WGS84 koordinate system seems to be another than usual WGS84.
Regards
Bernd
Am 13.03.2013 14:49, schrieb G. Allegri:
> I'm not sure if they are milliseconds.
> O would try to divide the last digits by 3600000 (and sum to the rest)
> 2013/3/13 Bernd Laskowski <Bernd.Laskowski at reichshof.de
> <mailto:Bernd.Laskowski at reichshof.de>>
> Hi Giovanni,
> If I try this the points are fare away from the real point.
> What about the Number rigth from seconds (f.e. 2 or 9)?
> Regards
> Bernd
> Am 13.03.2013 14:09, schrieb G. Allegri:
>> degrees+minutes/60+seconds/3600
>> e.g.
>> 50+(96/60)+(6/3600) = 51.601666...
>> giovanni
>> Hi all,
>> how I can convert data in following format to get decimal
>> degrees.
>> 50°96'06''2N/7°70'18''3O
>> 50°96'39''9N/7°68'56''3O
>> 50°95'72''9N/7°68'00''5O
>> Garmin GPS configuration:
>> Positionsformat: UTM UPS
>> Kartenbezugssystem: WGS84
>> Kartensphäroid: WGS84
>> Would WGS84/UPS North (EPSG 32661) in Qgis the correct
>> coordinate system?
>> I use ETRS89 (EPSG 25832)
>> Regards
>> Bernd
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giovanni Allegri
>> website: http://giovanniallegri.it <http://giovanniallegri.it>
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Gemeinde Reichshof
> I/10 Zentrale Verwaltung
> Bernd Laskowski
> Hauptstraße 12
> 51580 Reichshof - Denklingen
> Tel.: (02296) 801 - 313
> Fax: (02296) 801 - 395
> E-mail:Bernd.Laskowski at Reichshof.de <mailto:Bernd.Laskowski at Reichshof.de>
> Der Inhalt dieser E-Mail ist ausschließlich für den bezeichneten Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertreter sein sollten, so beachten Sie bitte, dass jede Form der Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des Inhalts dieser E-Mail unzulässig ist. Wir bitten Sie, sich in diesem Fall mit dem Absender der E-Mail in Verbindung zu setzen.
> Bei Abwesenheit des Adressaten, an den Sie eine E-Mail gerichtet haben, kann diese automatisch an dessen Vertreter weitergeleitet werden. Wir möchten Sie außerdem darauf hinweisen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschlüsselung unsicher ist, da für unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und Manipulation besteht. Wir übernehmen deshalb keine Verantwortung für den Inhalt dieser Nachricht, da eine Manipulation nicht ausgeschlossen werden kann. Obwohl wir alle angemessenen Vorkehrungen getroffen haben, um sicherzustellen, dass Anlagen dieser E-Mail Virus-geprüft sind, empfehlen wir dennoch, anhängende Dateien vor dem Öffnen durch Ihr eigenes Virus-Programm zu prüfen, da wir keinerlei Haftung für Schäden übernehmen, die infolge etwaiger Software-Viren entstehen könnten.
> Giovanni Allegri
Gemeinde Reichshof
Bernd Laskowski
Hauptstraße 12
E-mail: Bernd.Laskowski at Reichshof.de
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130313/258fcdbb/attachment.html>
