[Qgis-user] Lizmap Web Client and Plugin: new versions released !
kimaidou kimaidou at gmail.com
Sun Mar 17 06:39:23 PDT 2013
Hi list
We are pleased to announce the release of a new version of
LizMap-Web-Client 2.7.0 and a new version of the LizMap plugin (1.8.0) for
QGIS
This new version brings some interesting new features:
* Online documentation (build in restructuredText with Sphinx). It is now
only in French, but we will try to set up a pootle instance and start
translating it into english). For now, you can use Google translate, which
helps a bit I hope
It contains the plugin and Web application docs:
http://translate.google.fr/translate?sl=fr&tl=en&js=n&prev=_t&hl=fr&ie=UTF-8&eotf=1&u=http%3A%2F%2Fdocs.3liz.com%2Ffr%2F&act=url
* Printing Support
Users can print the first composer found in QGIS.  External baselayers
(Google and others) are not printed.
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/map-tab.html&usg=ALkJrhgFUsGomkk7H7r4wzidSPzS34OBMg#impression-simple
* Support for "annotations"
Users can add new features to a Spatialite or PostGIS layer of the QGIS
project. Once the geometry is created in the web interface, a popup with a
form will appear and let the user fill in the fields data. The form uses
nearly all the edit types (list of vales, checkbox, text edit, range,
etc.). Only the addition is available for the moment, hence the name
"Annotation" and not "Edition"
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/tools-tab.html&usg=ALkJrhiFHXV5cJ6wc8DFdtrvUKG143-_Vg#couches-d-annotation
* Geolocation
This tools allows the user to automatically find its position on the map.
For mobile devices, GPS is recognized and allows more precise positioning
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/map-tab.html&usg=ALkJrhgFUsGomkk7H7r4wzidSPzS34OBMg#positionnement-automatique
* Address search
A search input let the users search for an address. The geocoding engine is
currently Nominatim, which uses OpenStreetMap data (
http://nominatim.openstreetmap.org ). The search is restricted to the
extent of the QGIS project.
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/map-tab.html&usg=ALkJrhgFUsGomkk7H7r4wzidSPzS34OBMg#recherche-d-adresse
* Zoom History
The user can go back (and forward) while navigating in the map.
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/map-tab.html&usg=ALkJrhgFUsGomkk7H7r4wzidSPzS34OBMg#zoom-precedent-suivant
* Measure tools
The measuring tool allows the user to measure areas, perimeters and lengths.
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/map-tab.html&usg=ALkJrhgFUsGomkk7H7r4wzidSPzS34OBMg#outils-de-mesure
* Location layer
A dropdown list is generated from objects in a vector layer to provide an
automatic zoom on one of the objects of the layer. Up to 3 different layers
possible.
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/tools-tab.html&usg=ALkJrhiFHXV5cJ6wc8DFdtrvUKG143-_Vg#localiser-par-couche
*Rendering order for layers
In QGIS, we can decouple the rendering order of the layers and the order of
appearance of those in the legend. Lizmap now supports this feature.
* Server cache management
Possibility for the administrator when connected to remove the server cache
layer by layer from the online legend, via a red cross next to each layer.
* Client cache
It is now possible to configure the timeout for tiles in the browser cache.
This means that if the images on the map are in the browser cache and not
expired, no new request to the server is sent: the image is displayed
directly from browser cache. This optimizes the display of layers
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/interface/layers-tab.html&usg=ALkJrhgcno9HxUMm2AW3uQL1kJpLluf35w#utiliser-le-cache
* Ability to hide layers of the QGIS project
Just put the layers in a group called "hidden" and they will not be visible
in the web interface. This can be useful to hide the annotation layers, or
layers you wish to retain in the project but not published online.
http://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=fr&ie=UTF8&prev=_t&rurl=translate.google.fr&sl=fr&tl=en&u=http://docs.3liz.com/fr/lizmap-plugin/features/hide-layers.html&usg=ALkJrhiTrVlQpd9e1MqXivexBwaWOi6izQ
And other features:
* Management of web map scales: min and max scales are used to restrict the
display of the online map.
* Addition of an animated gif next to each layer during the loading of the
data.
* Added icons for all map tool menu and dialog boxes.
* Using the EPSG:3857 official projection instead of EPSG:900913 for
reprojection to external baselayers: remember to change your projects!
* Popup: Changing the way we call media files into HTML templates popup
(see documentation)
* Legend: possibility of transforming the parent groups in separate blocks
legend.
* Bug fixes and interface problems on some browsers.
* Added the Lizmap Web Client version number in the administration panel,
menu "Lizmap Configuration"
* Ability to keep session alive by checking a box on the login form
To see and test these features:
https://demo.lizmap.3liz.com/index.php/view/map/?repository=montpellier&project=montpellier
The complete source code of Lizmap Plugin and Lizmap Web Client, and the
documentation, is online at Github:
https://github.com/3liz/
To see all the code changes since the last official version 2.4.1
https://github.com/3liz/lizmap-web-client/compare/2.4.1...2.7.0
We would especially like to thank for this version 2.7.0:
* The Natural Park of Ballons des Vosges, which funded the development of
annotations, zoom history, the possibility of grouping parent groups in
blocks, and trusted us since the beginning of the Lizmap adventure.
* Andromede Océanologie, which funded the support for simple printing,
measure tool and geolocation tool.
* Salvatore Larosa for translating the plugin and Web application into
Italian.
* Everyone who gave feedback and tested Lizmap.
Regards
Michael Douchin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130317/327d603a/attachment.html>
