[Qgis-user] QGIS install fail on Ubuntu 12.04
    Lee
    muellerl at gmail.com
    Mon Mar 18 11:26:36 PDT 2013
Okay. I used:
*sudo apt-get --purge autoremove qgis*
It appeared to successfully remove a series of packages. Next I did:
*sudo apt-get install python-software-properties*
Seemed to work.
*sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
Executing: gpg --ignore-time-conflict --no-options
--no-default-keyring --secret-keyring /tmp/tmp.mZECgujMeJ
--trustdb-name /etc/apt/trustdb.gpg --keyring /etc/apt/trusted.gpg
--primary-keyring /etc/apt/trusted.gpg --keyserver
hkp://keyserver.ubuntu.com:80/ --recv
6B827C12C2D425E227EDCA75089EBE08314DF160
gpg: requesting key 314DF160 from hkp server keyserver.ubuntu.com
gpg: key 314DF160: "Launchpad ubuntugis-stable" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1*
Okay. Looking good.
*sudo apt-get update*
Received the following error:
E: Type 'eb' is not known on line 2 in source list
/etc/apt/sources.list.d/ubuntugis-ubuntugis-unstable-precise.list
E: The list of sources could not be read.*
Okay. Easy fixed. Went into the file stated and added the "d" to the
"eb" so it read "deb". Tried update again. No errors generated.
 sudo apt-get install qgis*
Everything appeared to work. So...
qgis
Warning: loading of qgis translation failed [/usr/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_US]*
QGIS launches, but I still don't have the capability to fetch plugins.
This is the error I was getting originally. So at the very least, QGIS
works again, but we haven't fixed my original problem. Other thoughts?
All the best,
Lee
ISA Certified Arborist MI-4148A
Registered Forester #46043
On Mon, Mar 18, 2013 at 2:00 PM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> Am 18.03.2013 18:50, schrieb Lee:
>  I'm not sure I'm following what you're suggesting that I try.
> There are several methods described at http://hub.qgis.org/projects/**
> quantum-gis/wiki/Download<http://hub.qgis.org/projects/quantum-gis/wiki/Download>how to install current versions of QGIS.
> I tried a lot, got some dependency break messages as you, and finally had
> success with the Ubuntugis unstable ppa. It might be useful to delete the
> qgis.org/debian entries from sources.list, and follow the advices here:
> <http://askubuntu.com/**questions/151941/how-can-you-**
> completely-remove-a-package<http://askubuntu.com/questions/151941/how-can-you-completely-remove-a-package>
> to clean your system.
> HTH,
> Andre Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130318/e0d5f064/attachment.html>
