[Qgis-user] [Qgis-developer] Database relations and nested forms in QGIS: Call for Funding
Andreas Neumann
a.neumann at carto.net
Wed Mar 20 00:47:35 PDT 2013
Hi again,
I wanted to add that the proposal also includes managing relations
(adding/removing relations) by picking one or more feature geometries in
the map or one or more records in a related table, once the relations
are defined in the relation manager and the widgets are defined accordingly.
Thanks,
Andreas
Am 20.03.2013 08:32, schrieb Andreas Neumann:
> Hi all,
> The Swiss QGIS user community is increasingly building application
> modules around QGIS. Most of these modules require database relations -
> not only 1:1, but also 1:n and n:m relations. Currently, only 1:1
> relations are supported (with some limitations) in QGIS through the
> table joins.
> Since many upcoming QGIS applications will require also 1:n and n:m
> relations we want to make database relations a core feature in QGIS.
> Matthias Kuhn from Switzerland already started work on this and will
> continue to work on it. Some swiss communities started funding this and
> other efforts in QGIS - now we are looking for some additional funding
> and are also approaching the international QGIS community for financial
> support.
> Matthias and Denis Rouzaud (both from Switzerland) already worked on the
> following forms and database improvements:
> * drag and drop forms designer - allows to easily re-order form widgets
> and group them in tabs and groups
> * combining forms and tables into a single window (dual view)
> * Allow to step through all records and forms one by one
> * Filters/Selections apply on both forms and table
> * database relations manager allows to set foreign key database
> relations (regardless of the provider - you can join f.e. a
> Postgis-table with a SQL-server table)
> The next steps would be the nested forms where one can embed one child
> form in another master form and the records are filled into the child
> form automatically based on the relation defined in the relations manager.
> We are looking for funding of CHF 13'000, approx. 10'500 € or 13'700 US$
> to complete this work for the nested forms.
> If you have an interest in database relations and more complex forms
> please consider to support this important QGIS feature that will in the
> future allow to build more complex tools and applications with QGIS and
> databases.
> If you are interested, please contact me and I can forward you the more
> detailed specification of what we plan with the nested forms.
> Thank you,
> Andreas
> Qgis-developer mailing list
