[Qgis-user] Rasterlite datasource gets always absolute path
    Jo
    doublebyte at lavabit.com
    Fri Mar 22 07:16:29 PDT 2013
I had exactly the same problem, but unfortunately I cannot manage to
load the database in my project other than having the absolute path
hardcoded :-(
This is the part of the original project (qgs)  file, that refers to the
rasterlite db:
     <projectlayers layercount="1">
         <maplayer minimumScale="0" maximumScale="1e+08" type="raster"
hasScaleBasedVisibilityFlag="0">
<id>RASTERLITE_tutorials_raster_table_mercator20130322144222187</id>
<datasource>RASTERLITE:/home/joana/git/GISforEAF/data/tutorials_raster.sqlite,table=mercator</datasource>
             <title></title>
             <abstract></abstract>
<layername>RASTERLITE:tutorials_raster,table=mercator</layername>
I tried to replace the absolute path on data source line, for a relative
path:
<datasource>RASTERLITE:./tutorials_raster.sqlite,table=mercator</datasource>
When I try to open the project, QGIS complains about "handling bad layers"!
I also tried this (since the project file is "sitting" on the same
directory of the database):
<datasource>RASTERLITE:tutorials_raster.sqlite,table=mercator</datasource>
And it comes up with the same error :-( I am a bit stuck here; I thought
the problem would be the GDAL driver:
http://www.gdal.org/frmt_rasterlite.html
But funny enough, when I use this syntax through GDAL directly, it
accepts the relative paths; for instance:
gdaladdo -ro RASTERLITE:../tutorials_raster.sqlite,table=mercator 2 4 8 16
works, without a problem.
I would appreciate a lot suggestions of how-to overcome this problem,
since I need to put a QGIS project in one folder, together with the data
- without absolute paths!
This is because I need to distribute this folder to other computers, so
it needs to be self contained and it must not have absolute references
on it.
Btw, I gave a try to the QConsolidate plugin:
http://hub.qgis.org/projects/qconsolidate
but unfortunately it converts the rasterlite layers into tiff files,
which is not exactly what I want (I want the project to refer to the
SQLite database and *not* to physical files on disk!
As I said before, any help would be highly appreciated. Thanks for your
time!
Joana
P.S.: If I don't find a neat solution for this, I am even considering
writing a script to update the paths on the project file...
