[Qgis-user] Convrting vector to raster: rasterize (vecor to raster ) in QGIS
Santiago Banchero
santiagobanchero at gmail.com
Fri Mar 22 19:09:33 PDT 2013
I attach a picture so you can understand better and the parameters that you
would see.
Best
Santiago
Usage: gdal_rasterize [-b band]* [-i] [-at]
[-burn value]* | [-a attribute_name] [-3d]
[-l layername]* [-where expression] [-sql select_statement]
[-of format] [-a_srs srs_def] [-co "NAME=VALUE"]*
[-a_nodata value] [-init value]*
[-te xmin ymin xmax ymax] [-tr xres yres] [-tap] [-ts width height]
* [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/*
* CInt16/CInt32/CFloat32/CFloat64}]* [-q]
<src_datasource> <dst_filename>
2013/3/22 Manuel Spínola <mspinola10 at gmail.com>
> Thank you very much Santiago,
> I don´t understand your suggestion. Could you be more specific.
> Best,
> Manuel
> 2013/3/22 Santiago Banchero <santiagobanchero at gmail.com>
>> Hi,
>> you need fix the *-ot* parameter manually and set a Data Type
>> according to your trouble.
>> Regards
>> Santiago
>>> Dear list members,
>>> I am trying to convert a vector (shapefile) to a raster using the option
>>> Conversion -> rasterize under the raster menu, however I don´t understand
>>> the result that I am getting. The values of the raster does not make any
>>> sense the min: -1.79769e+308 and max: 1.79769e+308
>>> I am also doing the same thing in R and I got reasonable results, the
>>> values of the raster goes from 1 to 10, the ones that I expected.
>>> > raster_agri
>>> class : RasterLayer
>>> dimensions : 300, 300, 90000 (nrow, ncol, ncell)
>>> resolution : 207.5064, 133.2117 (x, y)
>>> extent : 440239.3, 502491.2, 1032331, 1072294 (xmin, xmax, ymin,
>>> ymax)
>>> coord. ref. : +proj=tmerc +lat_0=0 +lon_0=-84 +k=0.9999 +x_0=500000
>>> +y_0=0 +ellps=WGS84 +units=m +no_defs
>>> data source : in memory
>>> names : layer
>>> values : 1, 10 (min, max)
>>> And even when I import this to QGIS the values of the raster does not
>>> make any sense either min: -2.14748e+09 and max: 2.14748e+09
>>> Any clue on this.
>>> Best,
>>> Manuel
>>> *Manuel Spínola, Ph.D.*
>>> Instituto Internacional en Conservación y Manejo de Vida Silvestre
>>> Universidad Nacional
>>> Apartado 1350-3000
>>> Heredia
>>> COSTA RICA
>>> mspinola at una.ac.cr
>>> Teléfono: (506) 2277-3598
>>> Fax: (506) 2237-7036
>>> Personal website: Lobito de río<https://sites.google.com/site/lobitoderio/>
>>> Institutional website: ICOMVIS <http://www.icomvis.una.ac.cr/>
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Santiago Banchero
> Apartado 1350-3000
> Heredia
> COSTA RICA
Santiago Banchero
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130322/6c72efdb/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130322/6c72efdb/attachment.png>
