[Qgis-user] Field Calculator calculates negative area
Lene Fischer
lfi at life.ku.dk
Mon Mar 25 08:14:52 PDT 2013
Hi Morten
When I make the calculation for 999 øvrige comes out correct.
Regards
Lene Fischer
________________________________________
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af magerlin [MAP at ramboll.dk]
Sendt: 25. marts 2013 16:07
Til: qgis-user at lists.osgeo.org
Emne: [Qgis-user] Field Calculator calculates negative area
Hi
I wanted to calculate the areas of some polygons and used the $area in the
field calculator.
But one of my (rather complicated) polygons ended up having a negative area.
As can be seen from the below screen shot the derived area from the identify
tool is correct (a least it is positive) while the value Areal which I
calculated is negative:
<http://osgeo-org.1560.n6.nabble.com/file/n5042754/Negative_Area.png>
A peculiar thing is that until I save my shape file the area is correct in
the field calculator (Area2 is no saved yet):
<http://osgeo-org.1560.n6.nabble.com/file/n5042754/Negative_Area2.png>
The shap file can be doanloaded here: Storzoner.zip
<http://osgeo-org.1560.n6.nabble.com/file/n5042754/Storzoner.zip>
Also Version 1.9 calculates a negative value even thoug it firsts show up
when I close and reopen the attribute table.
Regards Morten
Qgis 1.8.0 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/Field-Calculator-calculates-negative-area-tp5042754.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
