[Qgis-user] Field Calculator calculates negative area
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Mon Mar 25 08:35:20 PDT 2013
It seems that this is a limitation for integer. You can set higher digit values for reals.
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im
> Auftrag von magerlin
> Gesendet: Montag, 25. März 2013 16:32
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] Field Calculator calculates negative area
> Hi Stefan
> You're right - I had not noticed the 10 digit limit.
> But since you can not set it higher I had to calculate area as square kilometers instead
> and got the right number.
> Perhaps Qgis should give some kind of warning - it was only because of the negative
> number I noticed it, had it been positive I might not have noticed...
> Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Field-Calculator-
> calculates-negative-area-tp5042754p5042763.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
