[Qgis-user] Field Calculator calculates negative area
magerlin
MAP at ramboll.dk
Mon Mar 25 08:40:42 PDT 2013
Hi Lene
I am aware that the polygons not are topological OK - I've tried to use
Grass to clean them but had no luck.
But anyhow I think Qgus should be able to calculate the areas - I could have
been in a situation where overlapping polygons were OK.
As can be from the other correspondance it seems to come from a 10 digit
limitation on integers.
Regards Morten
Qgis 1.8.0 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/Field-Calculator-calculates-negative-area-tp5042754p5042771.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
