[Qgis-user] Label with HTML-expressions
Andreas Neumann a.neumann at carto.net
Tue Mar 26 06:10:35 PDT 2013
 Hi Lene,
 hm - in that case I don't know. You need a fairly recent 1.9x though -
 not the one before the API break I think.
 Maybe it requires a block element like <div>...</div> or <p>...</p>.
 Can you try with such a block element?
 I doubt though, that a link inside a map-tip would work well - as the
 maptip always moves with the mouse cursor - and you can't reach that
 link.
 Andreas
 On Tue, 26 Mar 2013 08:37:20 +0000, Lene Fischer wrote:
> 1.9
> ________________________________________
> Fra: qgis-user-bounces at lists.osgeo.org
> [qgis-user-bounces at lists.osgeo.org] på vegne af Andreas Neumann
> [a.neumann at carto.net]
> Sendt: 26. marts 2013 09:36
> Til: qgis-user at lists.osgeo.org
> Emne: Re: [Qgis-user] Label with HTML-expressions
>  Hi,
>  Are you using QGIS 1.8 or QGIS 1.9x? As far as I know this only
> works
>  in 1.9x (master version).
>  Andreas
>  On Tue, 26 Mar 2013 07:49:15 +0000, Lene Fischer wrote:
>> I´ve tried to insert a HTML  in the label-expression.
>> The url in coloumn 'www'
>> 'link [1]'
>> The output example looks like a link (blue and underline), but when
>> I
>> look at the map - it is filled with non interpreted text.
>> Is there a "render as HTML" label option I have overlooked?
>> Regards
>> Lene Fischer
>> Links:
>  Andreas Neumann
>  Böschacherstrasse 10A
>  8624 Grüt (Gossau ZH)
>  Switzerland
> Qgis-user mailing list
 Andreas Neumann
 Switzerland
