[Qgis-user] Label with HTML-expressions
Lene Fischer
lfi at life.ku.dk
Tue Mar 26 06:18:08 PDT 2013
Hi Nathan and Andreas
No it is not in the composer - even though it would be nice if the labels in the canvas AND in the printcomposer could be a link.
I´v e also tried the MapTip - with same result. I think it must be a "bug" because the example in the label shows the element as a normal link. It would be nice if it was there. Just as in MapInfo....
Regards
Lene
________________________________________
Fra: Nathan Woodrow [madmanwoo at gmail.com]
Sendt: 26. marts 2013 14:14
Til: Lene Fischer
Cc: qgis-user
Emne: Re: [Qgis-user] Label with HTML-expressions
Lene,
Are you talking about HTML map labels or HTML composer labels?
- Nathan
On Tue, Mar 26, 2013 at 5:49 PM, Lene Fischer <lfi at life.ku.dk<mailto:lfi at life.ku.dk>> wrote:
I´ve tried to insert a HTML <a href> in the label-expression.
The url in coloumn 'www'
'<a href="[% "www" %]" target="_blank">link</a>'
The output example looks like a link (blue and underline), but when I look at the map - it is filled with non interpreted text.
Is there a "render as HTML" label option I have overlooked?
Regards
Lene Fischer
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130326/513b7a1f/attachment.html>
