[Qgis-user] SAGA-GIS on OS X 10.7
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Mar 26 08:14:53 PDT 2013
Ah, if you're having problems there also, I suggest downloading and installing wxPython from wxpython.org.  wxPython includes wxWidgets.  Saves a long compilation.  Then you just need to run a command before building SAGA (instead of building wxWidgets steps):
export PATH="/usr/local/lib/wxPython-2.9.4.0/bin:$PATH"
On Mar 26, 2013, at 9:59 AM, Jesus Munoz Serrano wrote:
> Thanks a lot william and sorry about my questions. I'm not used to work with the terminal nor python.
> So I downloaded and installed the UnixImageIO framework. But now, I have to build wx-widgets. I created build-cocoa-debug, then cd build-cocoa-debug and run:
> ../configure --enable-unicode --enable-debug --enable-shared --enable-monolithic --with-osx_cocoa --enable-macosx_arch=x86_64 \
> --with-macosx-version-min=10.7 \
> --with-macosx-sdk=/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.7.sdk
> I am getting the same error again. Also I think I am gonna have the same problem building GNU packages and SAGA. There is any easier way to do it? Sorry again for the questions.
> Jesus
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
