[Qgis-user] Label with HTML-expressions
Nathan Woodrow madmanwoo at gmail.com
Tue Mar 26 15:53:16 PDT 2013
Lene,
If you are talking about the hotlink stuff.  QGIS can do this using Layer
Actions.  Have a look in the properties dialog under the Actions tab for
the layer.
- Nathan
On Wed, Mar 27, 2013 at 1:30 AM, Lene Fischer <lfi at life.ku.dk> wrote:
>  Hi Nathan
> In MapInfo - at the top of Layercontrol there is a possibillity to set a
> link, so the map can be interactive.
> In my case I would like to make the qgis map interactive to external links
> - and then upload to QGISCloud.
> Regards
> Lene
> *Fra:* Nathan Woodrow [madmanwoo at gmail.com]
> *Sendt:* 26. marts 2013 14:22
> *Til:* Lene Fischer
> *Cc:* qgis-user
> *Emne:* Re: [Qgis-user] Label with HTML-expressions
>   Lene,
>  HTML maps labels are not supported....yet. The example label is
> rendering the link because QLabels support HTML, which is used to preview
> the label result.
>  What would be you use case for having clickable labels in the map
> window? An interactive map?  I'm not sure MapInfo could do this.
>  - Nathan
> On Tue, Mar 26, 2013 at 11:18 PM, Lene Fischer <lfi at life.ku.dk> wrote:
>>  Hi Nathan and Andreas
>> No it is not in the composer - even though it would be nice if the labels
>> in the canvas AND in the printcomposer could be a link.
>>  I´v e also tried the MapTip - with same result. I think it must be a
>> "bug" because the example in the label shows the element as a normal link.
>> It would be nice if it was there. Just as in MapInfo....
>>  Regards
>> Lene
>> ________________________________________
>> *Sendt:* 26. marts 2013 14:14
>> *Til:* Lene Fischer
>> *Cc:* qgis-user
>>    Lene,
>>  Are you talking about HTML map labels or HTML composer labels?
>>  - Nathan
>> On Tue, Mar 26, 2013 at 5:49 PM, Lene Fischer <lfi at life.ku.dk> wrote:
>>>  I´ve tried to insert a HTML <a href> in the label-expression.
>>> The url in coloumn 'www'
>>> '<a href="[% "www" %]" target="_blank">link</a>'
>>>  The output example looks like a link (blue and underline), but when I
>>> look at the map - it is filled with  non interpreted text.
>>>  Is there a "render as HTML" label option I have overlooked?
>>>  Regards
>>>  Lene Fischer
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130327/ff62515b/attachment.html>
