[Qgis-user] manually change FID/OID
    José Pedro Santos
    zpsantos1 at hotmail.com
    Wed Mar 27 02:29:37 PDT 2013
I don't understand exactly why you want to change the ID number but be careful doing that, like Stefano said and correctly, you can corrupt the all table.
Best Regards,
Jose Santos
Date: Tue, 26 Mar 2013 18:45:12 +0100
To: chris.roettger at web.de
CC: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] manually change FID/OID
Maybe I misunderstood what are you trying to do, just be aware that manually modifying FID or OID in a shapefile or geoDb feature class is likely to corrupt them.
Cheers,
Stefano
Il giorno 26/mar/2013 18:40, "Christian Röttger" <chris.roettger at web.de> ha scritto:
no, i want to do it the other way arround. the problem is that i want to change the FID value, which is generated by arcgis or qgis automatically (the grey numbers in the first column). i have already a column with id values. i want to assign the FID/OID with their values.
Am 26.03.2013 17:07, schrieb José Pedro Santos:
Hi Christian,
Why you don't create a new column with the ID values that you want? If
you want to edit some columns or rows you can use the Field Calculator.
Best Regards,
José Santos
Date: Tue, 26 Mar 2013 16:59:08 +0100
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] manually change FID/OID
i have the following problem: If i export a postgis db with qgis it
mixes up the rows. On the first position in the attribute table is a
value with id 2400 but should be 0 or 1
e.g.
       id      objectname
0 | 2400 | name 2400  ...
1 | 828   | name 828   ...
When i inspect the database, everything seems to be ok, as the line with
id =1 shows up on the top position and id is set as primary key.
Has anybody an idea how i can get my table back in the right order or
how to manually update the FID/OID with my id values?
I need that for an geotools importer which reads the FID and i cant
change the import parameters.
Thanks christian
_______________________________________________ Qgis-user mailing list
Qgis-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130327/2d388e0d/attachment.html>
