[Qgis-user] Label with HTML-expressions
Antonio Vico avicomartin at gmail.com
Wed Mar 27 09:32:11 PDT 2013
Hi magerlin,
Can you explain how to have you do this?.
On 27/03/13 13:54, magerlin wrote:
> Hi Lene
> A simple solution could be the HTML Image Map Plugin.
> If you have a shape file with attributes like a text and the corresponding
> link you can use the plugin to create a simple html file and png file of the
> map background ending up looking like this:  Simple example
> <https://dl.dropbox.com/u/8189384/HTML_Imagemap/index.html.html>   (click on
> the text Tivoli).
> Only caveat can be the size of the png background file - in this example it
> is 1.3 MB.
> You can also specify mouse over actions and more.
> Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Label-with-HTML-expressions-tp5042897p5043276.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
