[Qgis-user] Label with HTML-expressions
    Thomas Baumann
    expedio at gmail.com
    Thu Mar 28 06:35:02 PDT 2013
Hello,
could it be that there is a bug in the recent Web-Client?
I just set up the webclient an hour ago, so it should be the newest version.
The tooltip itselft is working but the click-popup does not appear.
In Firebug I can see that the get-feature-info-request is done and that a
correct answer is also coming back but that's it... no popup is opening but
also no error-messages in the firebug-console.
I also recognised that the tree-panel in the east-region seems to be
missing in the GUI.js.
any idea what's wrong?
best wishes,
Thomas
2013/3/28 Bernhard Ströbl <bernhard.stroebl at jena.de>
> Hi Antonio,
> the popups were merged into qgis-web-client last tuesday, so you should
> update your site to the latest version.
> If you activate the infoButton and click on a feature a popup opens
> displaying all the fields you allowed for display.
> If you activate the infoButton and move the mouse over a feature a small
> popup opens showing the contents of your infoField: if you use
> GetProjectSettings this is the field you assigned in your project as "map
> tip display" for the layer. If you use GetCapabilities you need a field
> named "tooltip" in your layer (can be an alias)
> hope this helps
> Bernhard
> Am 28.03.2013 12:58, schrieb Antonio Vico:
>> Hi Bernhard, thanks for your reply
>> I am installed and configured qgis-server and qgis-web-client in debian
>> squeeze for testing and work fine, but I don't know how to make popups
>> like the link I wrote.
>> I am configured GlobalOptions.js and create different
>> "qgiswebclient.html" according to the tutorial Publishing multiple
>> projects with QGIS Server
>> <http://linfiniti.com/2012/02/**publishing-multiple-projects-**
>> with-qgis-server/<http://linfiniti.com/2012/02/publishing-multiple-projects-with-qgis-server/>
>> at
>> (thanks to Tim Sutton for your work) but I don't hanve found
>> documentation about popup. My Google search only show popup about
>> OpenLayers.
>> What files need to be configured for show popup ?
>> El 28/03/2013 8:12, Bernhard Ströbl escribió:
>>> Hi Antonio,
>>> qgis-web-client [1] is a JavaScript webmap client based on GeoExt
>>> (which is based on ExtJS and OpenLayers). You do not need any JS
>>> yourself, all you need is doing the setup.
>>> Bernhard
>>> [1] https://github.com/qgis/qgis-**web-client<https://github.com/qgis/qgis-web-client>
>>> Am 27.03.2013 22:00, schrieb Antonio Vico:
>>>> I reply to myself. I tested the plugin. Initially I thougth that work
>>>> like a popup in openlayers and I do the answer for this.
>>>> I visited this link that use qgis-web-client and show images in popup
>>>> when cursor is over certains icons.
>>>> http://webgis.uster.ch/maps/**stadtentwaesserung/wc_anlagen?**
>>>> format=image/jpeg&**visibleLayers=WC-Anlagen,**
>>>> Gemeindegrenze,Pixelkarten%**20und%20%C3%9Cbersichtsplan&**
>>>> searchtables=&startExtent=**692000,241500,700100,249000&**
>>>> maxExtent=692000,241500,**700100,249000<http://webgis.uster.ch/maps/stadtentwaesserung/wc_anlagen?format=image/jpeg&visibleLayers=WC-Anlagen,Gemeindegrenze,Pixelkarten%20und%20%C3%9Cbersichtsplan&searchtables=&startExtent=692000,241500,700100,249000&maxExtent=692000,241500,700100,249000>
>>>> This is that I want to do. I think this is a modification in javascript
>>>> in the openlayers files used in qgis web client but I don't know about
>>>> javascript and can't do it
>>>> ______________________________**_________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>> __________ Information from ESET Mail Security, version of virus
>>>> signature database 8169 (20130327) __________
>>>> The message was checked by ESET Mail Security.
>>>> http://www.eset.com
>>> http://www.eset.com
>> signature database 8171 (20130328) __________
>> http://www.eset.com
>> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130328/d00480fa/attachment.html>
