[Qgis-user] QGIS-master - Printing above A2 shrinks map contents in output
Alexandre Neto senhor.neto at gmail.com
Thu Mar 28 09:26:46 PDT 2013
I have created a ticked for this:
http://hub.qgis.org/issues/7468
Alexandre Neto
On Thu, Mar 28, 2013 at 4:04 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> Using QGIS-master (4189f45) in windows 7 64 bit, Printing a very simple
> layout (only vector layers) in any format above A2 gives a correct size
> output, but all map contents (including legend) reduced to a size near A2.
> In QGIS 1.8, instead of resizing the map contents, part is trimmed on the
> right size of the paper.
> Using save as PDF the problem does not occur in neither of the versions.
> Here some example files:
> http://dl.dropbox.com/u/110618644/qgis_print/A1_qgis1.8.print_to_pdf.pdf
> http://dl.dropbox.com/u/110618644/qgis_print/A1_qgis1.9.print_to_pdf.pdf
> http://dl.dropbox.com/u/110618644/qgis_print/A1_qgis1.9.save_as_pdf.pdf
> I don't think it's related to any other ticket (memory related)
> http://hub.qgis.org/issues/4821
> http://hub.qgis.org/issues/6498
> http://hub.qgis.org/issues/5840
> http://hub.qgis.org/issues/3687
> Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130328/9588a1d4/attachment.html>
