[Qgis-user] GRASS not accessible in latest debian-nightly
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed May 1 01:41:43 PDT 2013
Hi there,
with todays update, the GRASS plugin is now able to be activated without
an error and the toolbox works from within QGIS.
Still, GRASS launched from terminal throws errors and doesn't start up.
Cleaning up temporary files ...
Starting GRASS ...
access: No such file or directory
FEHLER: LOCATION << /tmp/sextante/grassdata/temp_location >> ist nicht
         vorhanden.
python: can't open file '/usr/lib/grass64/etc/wxpython/gis_set.py': [Errno
2] No such file or directory
Received EXIT message from GUI.
GRASS is not started. Bye.
When i now just for fun add the missing folders grassdata/temp_location,
the error for this is gone, but:
Starting GRASS ...
FEHLER: MAPSET PERMANENT nicht gefunden.
When I add a PERMANENT-folder to this path, this error is gone as well,
but there is still the missing /usr/lib/grass64/etc/wxpython/gis_set.py
In that folder, there is only a gis_set.tcl !
I did not make anything unusual, just installed qgis from the repo.
Any hints?
Am 30.04.2013, 21:09 Uhr, schrieb Bernd Vogelgesang
<bernd.vogelgesang at gmx.de>:
> Hi,
> just made a fresh install of qgis from the debian-nightly repository (on
> Linux Mint 14 64bit).
> When i try to activate the GRASS plugin from the plugin manager, it
> fails with: "G_getenv(): Variable GISDBASE not set"
> Ok, then i tried to launch GRASS from the terminal.
> Result:
> Starting GRASS ...
>          vorhanden.
> [Errno 2] No such file or directory
> The funny thing is, that GRASS functions through Sextante work well.
> Bug or feature , err, i mean, packaging problem, Sextante problem, QGIS
> problem, or user problem?
> Cheers
> Bernd
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
