[Qgis-user] EPSG:3987 is recognized in QGIS 2.0.1 on Windows 8.1 but not Arch Linux
Saulteau Don sault.don at gmail.com
Tue Nov 5 17:22:28 PST 2013
Evening list,
I've got some shapefiles that came without a .prj component but the
data source sent me confirmation of the proj details and I think I've
confirmed that the data was projected using EPSG:3978 (NAD83 / Canada
Atlas Lambert).
I've zipped them in my dropbox at https://db.tt/EO53JsUR
I applied that projection to a resultant shapefile and my data is now
lining up, but this is only on Windows 8.1 when QGIS is installed from
the osgeo4w 64-bit installer.
But opening the same shapefile on Arch Linux, QGIS 2.0.1 can't
recognize the projection and
instead gives it the wrong parameters and as:
USER:100000 -  * Generated CRS
(+proj=lcc +lat_1=49 +lat_0=49 +lon_0=-95 +k_0=1 +x_0=0 +y_0=0
+ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs)
So it's not lining up to other data.
It should instead be:
(+proj=lcc +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0
which is EPSG:3978
What can I do on Arch Linux so that EPSG:3978 can be
recognized, it isn't in the projection list like it is on Windows...
Not sure if this is because of something lacking in the proj4 library
or is it a QGIS thing? Can it be compiled in by default like on
Windows?
Any help is appreciated, thanks =)
SaultDon
