[Qgis-user] How do I georeference an xls file opened in QGIS 2.0
Minoru Akagi
akaginch at gmail.com
Tue Nov 5 19:13:57 PST 2013
Hi Brent, Giovanni and Richard,
I can open an excel sheet as a point layer with a VRT file.
An example of vrt file:
<OGRVRTDataSource>
<OGRVRTLayer name="points">
<SrcDataSource>points.xls</SrcDataSource>
<SrcLayer>Sheet1</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
</OGRVRTLayer>
</OGRVRTDataSource>
XLS driver is read-only, but newly supported ODS [1] and XLSX [2]
drivers can also write. So we can edit spreadsheet directly in QGIS.
An tip to correctly add points into spreadsheet layer is including at
least one decimal in each x and y column in advance. Making x field
and y field uneditable in the properties dialog may lead to
comfortable editing.
[1] http://www.gdal.org/ogr/drv_ods.html
[2] http://www.gdal.org/ogr/drv_xlsx.html
Minoru
