[Qgis-user] Scale based label rendering
Andreas Neumann
a.neumann at carto.net
Wed Nov 6 08:54:22 PST 2013
Hi Ross,
I sucessfully use $scale - it should just work, otherwise it is a bug
either in your statement or in QGIS.
I guess in your example your statement is wrong as AND/OR can only be
combined with boolean values (true/false). In your case you combine a
number with another number with OR and of course your statement fails.
You could write your statement with nested CASE statements, such as:
CASE WHEN type = 'town' THEN
CASE WHEN $scale < 100000 THEN 15 ELSE 10 END
WHEN type = 'city' THEN
CASE WHEN $scale < 100000 THEN 20 ELSE 15 END
END
You should get a warning if the syntax in your statement is not correct.
Andreas
Am 2013-11-06 17:44, schrieb McDonaldR:
> Thanks Bernhard
> That does work.
> Any idea how the $scale function works then? It is supposed to return
> the current scale of the map canvas but is only available in some
> contexts and will be 0 otherwise.
> Ross
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Bernhard
> Ströbl
> Sent: 06 November 2013 16:02
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Scale based label rendering
> Hi,
> not a solution but a workaround:
> simply copy the layer and define a different visibility scale range.
> Bernhard
> Am 06.11.2013 16:54, schrieb McDonaldR:
>> Hello list
>> I want to vary the size of my labels on features both by attribute and
>> map scale. So, for example, I have a layer of towns and villages and
>> I want towns labelled with a font size of 20 and villages with a font
>> size of 10. I can do this with in the label size expression builder:
>> CASE WHEN "type" = 'town' THEN 20 ELSE 10 END
>> Now, how can I vary the label size with scale? When the scale is
>> smaller than 1:100000 then towns must be size 15 and villages size 8.
>> I thought something like this would work:
>> (CASE WHEN "type" = 'town' AND $scale< 100000 THEN 20 ELSE 10 END) OR
>> (CASE WHEN "type" = 'town' AND $scale> 100000 THEN 15 ELSE 8 END)
>> I tried with the $scale function under Record category but then the
>> labels disappeared.
>> Any suggestions?
>> I am using QGIS 2.0.1-3 on Windows 7.
>> Thanks
>> Ross
>> Ross McDonald | GIS Data Coordinator | Resources Department, IT
>> Division | Angus Council, Angus House, Orchardbank Business Park,
>> Forfar, DD8 1AT
>> T: 01307 476419 | F: 01307 476401 | E:
>> mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk> | W: Angus
>> Maps<http://www.angus.gov.uk/maps/map_home.cfm>
>> This message is strictly confidential. If you have received this in
>> error, please inform the sender and remove it from your system. If
>> received in error you may not copy, print, forward or use it or any
>> attachment in any way. This message is not capable of creating a legal
>> contract or a binding representation and does not represent the views
>> of Angus Council. Emails may be monitored for security and network
>> management reasons. Messages containing inappropriate content may be
>> intercepted. Angus Council does not accept any liability for any harm
>> that may be caused to the recipient system or data on it by this
>> message or any attachment.
>> __________ Information from ESET Mail Security, version of virus
>> signature database 9013 (20131106) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> http://www.eset.com
> http://www.eset.com
