[Qgis-user] Difference: EPSG 3004 - EPSG 102092
Paolo
e-paul at tiscali.it
Thu Nov 7 03:43:26 PST 2013
Yes, actuallyI am reprojecting rasters from Gauss Boaga Roma 40 Monte
Mario zone 2 to ED50UTM33.
Errors are huge if I use 102092, but they are very small using 3004.
Further research lead me to discover even more, appearingly identical,
reference systems:
- Monte Mario Italy 2.prj (codice EPSG 3004);
- Monte Mario (Rome) Italy 2.prj (codice EPSG 26592);
- Roma 1940 Gauss Boaga Est.prj (codice EPSG 102094),
This is even more confusing, and will require some more studying.
Regards,
Paolo
Il 07/11/2013 10:37, G. Allegri ha scritto:
> As you can see, 102092 has the average transformation parameters to
> WGS84, which brings some more precision during datum transformation. I
> suppose you're reprojecting the data to some different CRS.
> giovanni
> Il 07/nov/2013 08:33 "Paolo" <e-paul at tiscali.it
> <mailto:e-paul at tiscali.it>> ha scritto:
> Oops... I forgot the most important part in my first post. Here
> are the edfinitions:
> EPSG 3004 - Monte Mario / Italy zone 2:
> +proj=tmerc +lat_0=0 +lon_0=15 +k=0.9996 +x_0=2520000 +y_0=0
> +ellps=intl +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> +units=m +no_defs
> EPSG 102092 - Monte_Mario_Italy_2:
> +ellps=intl +units=m +no_defs
> 3004 works well with my data, while 102092 does not.
> There appears to be a relatively large shift, in the order of tens
> or hundreds meters,monstly along the north - south direction.
> Thanks
> Paolo
> Il 07/11/2013 00:47, G. Allegri ha scritto:
>> In QGIS they appear having the same definition, Could you paste
>> the 102092 definition that you have?
>> giovanni
>> 2013/11/6 Paolo <e-paul at tiscali.it <mailto:e-paul at tiscali.it>>
>> Hello,
>> I am a relatively recent QGIS user. I am at the moment using
>> version 2.0 - Dufour.
>> I would like to ask a simple question about two different
>> datums I am experiencing problems with.
>> They are: EPSG 102092 and EPSG 3004.
>> Accordinf to my (short) research, they are supposed to be
>> exactly the same datum, but the definitions in QGIS are
>> different.
>> If I use 3004, the specific data set I'm using will overlap
>> properly with the other datasets, but it will not if I use
>> 102092.
>> Can anybody help me getting a better understanding of this
>> behaviour?
>> Thanks
>> Paolo
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/4eb4ffd1/attachment.html>
