[Qgis-user] Difference: EPSG 3004 - EPSG 102092
Paolo
e-paul at tiscali.it
Thu Nov 7 06:09:57 PST 2013
I realize I still need to learn much.
Thanks for taking time to explain.
Paolo
Il 07/11/2013 14:59, G. Allegri ha scritto:
> If I understand well, the datum shift parameters are required in
> order to improve the accuracy of the conversion between 3004 and
> other RS as ED50 UTM33, while they are not needed for conversion
> between 102092 and e.g. WGS84?
> The shift parameters are alway needed to obtain higher precision for
> CRS trasformations where the datums are different. When a transform
> from datum A to datum B is required, Proj4 (the engine underlying SRS
> and projections) does datum A -> WGS84 -> datum B. The shift
> parameters (+towgs84) are used my Proj4 to manage the intermediated
> transformations to (and from) WGS84, which is kind of a "pivot CRS".
> So, they're should be always employed. 102092 does not define them,
> that's why you get worst results.
> giovanni
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/3a0ffd16/attachment.html>
