[Qgis-user] Matplotlib needs Pyparsing (impossible to install Semi-automatic classification plugin)
Jesus Munoz Serrano jesusmunozserrano at gmail.com
Thu Nov 7 08:27:47 PST 2013
Thanks a lot, William.
I could install pyparsing following your advice. However, when I try to install the semi-automatic classification plugin it tells me:
	The plugin depends on some components missing in your system. You need to install the following python module in order 	 to enable it:
		ProcessingUtils
Should I install it with sudo /usr/bin/easy_install ProcessingUtils?
Additionally, I checked my Library folder under my home directory and I found 2 things:
	- there is no Python folder (It only uses extra python modules from /Library/Python/2.x/site-packages)
	- I have a folder called Enthought where I can find Canopy_64bit (even if I removed from my applications folder). Should I delete this folder?
thanks
On Nov 7, 2013, at 3:32 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Ah.  My QGIS uses the system python, and will ignore any other python and python modules.  It only uses extra python modules from /Library/Python/2.x/site-packages.
> There are instructions in my matplotlib for installing pyparsing.  I discovered this requirement at the last second when packaging, and I hope to eventually make it automatic.
> Note that if you have installed another python, its tools might override the system python in a Terminal, so you might need to use:
>  sudo /usr/bin/easy_install pyparsing
> On Nov 7, 2013, at 2:13 AM, Jesus Munoz Serrano wrote:
>> yes, I downloaded QGIS from kingchaos.com. I also downloaded all the packages from your website except from pyparsing.
>> On Nov 7, 2013, at 12:49 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>> Are you using my QGIS package?
>>> On Nov 6, 2013, at 12:43 PM, Jesus Munoz Serrano wrote:
>>>> Dear listers,
>>>> I've been trying to install the semi-automatic classification plugin for quite a while already without any success. I am using Mac OS X 10.8.5 y QGIS 2.0.1.
>>>> I have installed matplotlib first and then pyparsing 2.0.1 (by the python setup.py install command in the terminal). Still when I try to install the plugin a warning will show telling me:
>>>> 	The plugin is broken. Python said:
>>>> 	matplotlib requires pyparsing
>>>> Also tried uninstalling python and installing it again through the enthought Canopy 1.1 installer (which I believe comes with all the required packages) but the same warning will show.
>>>> Does anybody know how to solve this problem?
>>>> Thanks in advance,
>>>> Jesus
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/482d596b/attachment.html>
