[Qgis-user] Matplotlib needs Pyparsing (impossible to install Semi-automatic classification plugin)
William Kyngesburye
woklist at kyngchaos.com
Thu Nov 7 09:25:29 PST 2013
On Nov 7, 2013, at 10:27 AM, Jesus Munoz Serrano wrote:
> Thanks a lot, William.
> I could install pyparsing following your advice. However, when I try to install the semi-automatic classification plugin it tells me:
> The plugin depends on some components missing in your system. You need to install the following python module in order to enable it:
> ProcessingUtils
> Should I install it with sudo /usr/bin/easy_install ProcessingUtils?
ProcessingUtils is part of the Processing plugin and is handled by QGIS. If you updated your Processing plugin, it looks like ProcessingUtils was removed, so the semi-automatic classification plugin must be updated to support the new Processing plugin.
> Additionally, I checked my Library folder under my home directory and I found 2 things:
> - there is no Python folder (It only uses extra python modules from /Library/Python/2.x/site-packages)
Not python in your home folder, that's /Library/Python on the root of your HD.
> - I have a folder called Enthought where I can find Canopy_64bit (even if I removed from my applications folder). Should I delete this folder?
Probably. You should ask the Canopy developers to make sure about uninstalling steps.
> thanks
> On Nov 7, 2013, at 3:32 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Ah. My QGIS uses the system python, and will ignore any other python and python modules. It only uses extra python modules from /Library/Python/2.x/site-packages.
>> There are instructions in my matplotlib for installing pyparsing. I discovered this requirement at the last second when packaging, and I hope to eventually make it automatic.
>> Note that if you have installed another python, its tools might override the system python in a Terminal, so you might need to use:
>> sudo /usr/bin/easy_install pyparsing
>> On Nov 7, 2013, at 2:13 AM, Jesus Munoz Serrano wrote:
>>> yes, I downloaded QGIS from kingchaos.com. I also downloaded all the packages from your website except from pyparsing.
>>> On Nov 7, 2013, at 12:49 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>>> Are you using my QGIS package?
>>>> On Nov 6, 2013, at 12:43 PM, Jesus Munoz Serrano wrote:
>>>>> Dear listers,
>>>>> I've been trying to install the semi-automatic classification plugin for quite a while already without any success. I am using Mac OS X 10.8.5 y QGIS 2.0.1.
>>>>> I have installed matplotlib first and then pyparsing 2.0.1 (by the python setup.py install command in the terminal). Still when I try to install the plugin a warning will show telling me:
>>>>> The plugin is broken. Python said:
>>>>> matplotlib requires pyparsing
>>>>> Also tried uninstalling python and installing it again through the enthought Canopy 1.1 installer (which I believe comes with all the required packages) but the same warning will show.
>>>>> Does anybody know how to solve this problem?
>>>>> Thanks in advance,
>>>>> Jesus
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
>> - The Ruler of the Universe
> Qgis-user mailing list
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
