[Qgis-user] plugin icon visualization
Werner Macho
werner.macho at gmail.com
Fri Nov 8 06:23:28 PST 2013
Hi!
I guess what you missed it to include the
import resources_rc
in your main python file ..
might be that running the script fixed that for you..
but without in importing the resources_rc file the icon will not be
available to Qt
regards
Werner
On Fri, Nov 8, 2013 at 4:18 PM, McDonaldR <McDonaldR at angus.gov.uk> wrote:
> Hmmm, not sure then…
> I had a similar problem with my icons not showing up and had to rebuild the
> plugin using the two commands from the cookbook. That fixed it for me.
> Maybe someone else on the list will have some more information and advice?
> Ross
> From: Fabrizio murè [mailto:fabriziomure at gmail.com]
> Sent: 08 November 2013 14:14
> To: McDonaldR
> Subject: Re: [Qgis-user] plugin icon visualization
> thanks Ross for your reply!
> Yes I did steps you're mentioning and below I report my plugin folder
> configuration.
> Now I realized that the same situation (no icon displayed) happens with the
> OpenLayers Plugin 1.1.1
> Icons are correctly displayed in the Plugin Manager as reported below:
> It looks strange, migth it be a setting on my PC Windows desktop?
> I'm just curious to understand the reason..
> Thanks in advance.
> Fabrizio
> 2013/11/8 McDonaldR <McDonaldR at angus.gov.uk>
> Hi Fabrizio
> Do you have “icon.png” in your plugin folder?
> Did you run the two make commands to build the python files?
> pyuic4 -o ui_vector_selectbypoint.py ui_vector_selectbypoint.ui
> pyrcc4 -o resources.py resources.qrc
> This is the updated PyQGIS cookbook recipe for building a plugin:
> http://www.qgis.org/en/docs/pyqgis_developer_cookbook/plugins.html
> Ross
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Fabrizio murè
> Sent: 08 November 2013 11:41
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] plugin icon visualization
> Hi all, I'm relatively new with QGIS environment and I wish to learn how to
> develop a Python Plugin.. i'm reading useful info in the tutorial "Building
> a simple plugin"
> @http://www.qgisworkshop.org/html/workshop/plugins_tutorial.html
> Probably mine is a very trivial question...
> I'm able to activate my plugin in QGIS 2.0.1, but i have some problem with
> icon visualization on plugins toolbar and in the plugins menu.
> My plugin is present in the list but the button area appears empty, without
> icon "icon.png"
> How can i activate the icion visualization?
> I specified icon filename in the metadata.txt file..
> Thanks in advance, for any help you can give me!
> Regards,
> Fabrizio
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails may
> be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient system
> or data on it by this message or any attachment.
> Qgis-user mailing list
